MSS6x Flasher - Now released!
This is a sticky topic.
    Hi Tomba, thanks again for clarification.
    Originally posted by Tomba View Post
    If the changes you want to make are in the CAL/Data/Tune file then no RSA bypass is necessary on MSS65.
    I suspect manual/SMG config is in CAL/Data/Tune.
    The rest for sure is. I can make the changes to your file if you need help.
    I might come back to regarding that offer. Esspecially since you are also the man when it comes to injector programming. Details can be discussed via PM I guess. EDIT: Just found out I cannot send PMs yet 😓
    I have a CTEK MXS 10 battery charger which is also able to supply 10A 12V. I hope this is sufficient for a bench setup.
      Hello guys.
      Please tell me, how i can test wich firmware in my K+DCAN cable? EdiabasLib firmware or not? Thnx!
        Originally posted by EclipsE31 View Post
        Hello guys.
        Good question!
        I think by downloading the data from the interface and compare.
        Well, in the spirit of giving back, Ive decided to release our internal document on how to flash a compatible cable with ediabas lib. I have been following the M3 DME discussions since the comprehensive MSS54 thread till now. I think its time to give back. Let me know if I should upload another version without our website in
          Is it possible to test the bimmergeeks cable before the bypass procedure? If i use WinKFP to update the dct module (or any other module) and the process is 100% complete then my bimmergeeks cable is safe to use?
            Last week i got a update from the bmw dealer. So everthing updated well.
            Now i do a full read (60mins), load the full file, press bypass and got message "non stock binary" ???
            It is stock 100%, read and load file are the same, i have a 2012 DME. Im sure after the BMW dealer update and i have a 2012 DME i have to do the bypass flash. What should i do next??
            Its confusing is it possible to check if SOMEHOW my DME is already bypassed?
              Hello guys.
              I asked myself the same question and did not find an answer. In the end I used an arduino to update the cabel, just to be sure. However, in the manual linked by Tomba, it says at the end, that you should be able to update the software with their program. This only works if the software to beginn with is the correct one. So maybe you can check if it is possible to update your cabel. If not, it's wrong software. If yes, it's good one. As I said, I have not tested this method by myself. It was just popping into my mind when I was reading through the manual.
                Originally posted by ppm008 View Post
                xk thanx
                Setting Path to COM1 was the trick
                mss6x_flasher works great
                Can you post your config file here?
                Having similar issue.
                In the morning flashed 241E software, read full and did RSA bypass no problem. then changed hard drive on my laptop to do something else. Put it back and INPA all works. But MSS6x flasher keeps reporting unsupported ECU.
                Did disk check and still nothing. No clue at the moment.
                Tested car and cable on another laptop and works perfect. Only my laptop :-(....
                  A bit off topic but I wondered if anyone may have an answer, when I apply any changes via the binmod tool the program crashes everytime.
                  I have standard tools and a few others programs from Martyn on the laptop fwiw.
                    Generally there are 2 reasons for the app crash. One, running out of memory and two the file not being as the tool expects. Either way, I need the file you’re trying to modify to check the issue isn’t the later.
                      Guys I got this MSs65 v10 M6 bricked I flashed recovery with kess from another ECU full dump and went back to life I guess software was corrupted anyways I downloaded MSs65 flasher and read full flash long ISn ROM I read tune everything but I wanted to do immo off so I download btt eWS deleter and made immo off flashed it with MSs65 flasher without RSA DELETE now ECU bricked again so I repaired it again with kessv2 went back TO LIFE AGAIN and this time I did RSA DELETE AND FLASHED FAILED RSA DELETE FAILED,SO I TRIED TO REPAIR WITH KESS V2 AGAIN NOW WAKE UP ERROR NO COMMUNICATION OR UNKOWN ECU MSS65 FLASHER DOSNT EVEN RECONISE ECU ANYMORE HELP
                        friend I have a problem I need to read oisn from a dme mss65 but I'm having difficulty configuring my Icom interface could you help me through the service and help if possible
                          You cant use an ICOM with MSS6x Flasher, K/DCAN cable only.
                            Can mss65 be restored by bdm after unsuccessful rsa bypass programming? Dont know why xprog connects to left mcu, but not reads or writes data, ok reads and writes right mcu.
                              Was ECU tuned before?
                                Not sure, i needet dump for ews matching, before was connection by can, now not.
