What Else Should I Change When I do My Clutch?
    Wow, the original pin looks not bad at all, so I’m in the camp that don’t need the brass or ss pin replacement.
      Yeah I agree. I would choose the stock plastic pin over the metal ones if I were doing this again.
        Why not go with the SS pin? Noisy? Cost? I have an SS pin for my clutch job in the future but was thinking of getting the plastic one since I’m SMG as well.
          I have the SS pin on one of my M3 and I regret, it’s noisy. I will eventually drop tranny again to put OEM plastic back.
            I have the SS pin on one of my M3 and I regret, it's noisy. I will eventually drop tranny again to put OEM plastic back.
            Ah ok thanks for the feedback. Did you lube it when installing it? I'll have a plastic one in the basket for the next order of parts
              To give you an idea, if I want to get rid of the rattling noise it makes, I need to put a litttle bit of pressure on the clutch pedal… so annoying on a car with stock muffler. So even a bit of lube haven’t changed anything. And when replacing the pivot pin, make sure to measure depth precisely otherwise you will bust the clutch slave… ask me how I know…
              Also regarding the TOB, I think I prefer the one that comes with the LuK clutch kit. The TOB is pressed by the clutch fork and doesn’t get in contact straight as pressure is apply by clutch slave. Contact point of clutch fork is more with an angle. Pretty sure the LUK TOB apply load more evenly on the pressure plate during all of the slave travel.
                To give you an idea, if I want to get rid of the rattling noise it makes, I need to put a litttle bit of pressure on the clutch pedal… so annoying on a car with stock muffler. So even a bit of lube haven't changed anything. And when replacing the pivot pin, make sure to measure depth precisely otherwise you will bust the clutch slave… ask me how I know…
                Also regarding the TOB, I think I prefer the one that comes with the LuK clutch kit. The TOB is pressed by the clutch fork and doesn't get in contact straight as pressure is apply by clutch slave. Contact point of clutch fork is more with an angle. Pretty sure the LUK TOB apply load more evenly on the pressure plate during all of the slave travel.
                Yup sounds good, thanks. I'll get the plastic pin.
                  Great thread, thank you to all for the knowledge sharing. So, for a vehicle with exhaust and tune (my car), on the street, is the SACHS "Performance" kit 21212282667 recommended or, something else? I'mis finding the 667 part number kit show up various places, at vastly different prices and I'm not sure what "Performance" denotes compared to "stock" equivalent.
                    It's also less friction between the plastic pin and the fork, so less wear on the fork pivot dimple.
                      Are y'all changing 21511223302 Clutch Release fork lever with every clutch change? My Car has close to 55k miles and i want to do the clutch refresh one of these days. Car is SMG so i have tracked and done launches on this clutch and i feel it sliping sometimes in between shifts.
                      https://www.realoem.com/bmw/enUS/sho...diagId=21_0093 ​
                        At 55k, I'd reuse the fork.
                          I'm about to replace mine with SS, although the plastic one does look fine, but I wonder how is it noisier if there is a fork clip that keep together so it doesn't rattle?
                          Also, do you have the stock flywheel? otherwise the lightweight flywheel makes a lot more noise than this pin.
                            I'd just stick with the plastic pin and replace. The throw-out bearing will disintegrate first.
                              Maybe the clip is not strong enough to hold the fork to the pin tight on the road. It main function is to avoid the fork end fell off the pin, but not hold it tight enough.
                                Hi, everyone. I'm getting ready to drop my transmission to replace the clutch and associated parts. While I have everything apart, I want to refresh as many wearable parts as possible. The car is currently sitting at 175K miles.
                                ​Questions (thank you in advance):
                                1. Are the quantities of parts I've compiled correct?
                                2. Are the brand of parts I've compiled of good quality?
                                3. What parts are missing from my list that I should consider adding?
                                4. What bushings should be upgraded from stock rubber?
                                5. Does the clutch line need to be replaced? If so, OE or aftermarket?
                                6. What special tools are needed for the job that should be considered for procurement?
                                7. Should the detent pins and other accessible transmission components be replaced? Reference the 1st post of this thread.
                                This is the parts list I've compiled so far:
                                Part Part Number Brand Quantity Each Cost Total Cost Vendor Note
                                Crank Seal Cover Gasket 11141432240 Elring 1 $4.29 $4.29 Link
                                Rear Main Seal 11141706785 Corteco 1 $20.31 $20.31 Link
                                Clutch Kit 21212282667 LUK 1 $254.99 $254.99 Link
                                Flywheel 21212229900 LUK 1 $318.79 $318.79 Link
                                Flywheel Bolts 11222243051 OE 8 $3.62 $28.96 Link
                                Pressure Plate Bolts 7119906045 Genuine BMW 6 $1.69 $10.14 Link
                                Pilot Bearing 11211720310 Genuine BMW 1 $19.69 $19.69 Link
                                Throwout Bearing - LUK 1 $0.00 $0.00 - Included in clutch kit
                                Clutch Pivot Fork 21511223302 Genuine BMW 1 $33.87 $33.87 Link Steel
                                Clutch Pivot Fork Pin 21511223328 Genuine BMW 1 $9.19 $9.19 Link Plastic
                                Master Cylinder 21526773670 FTE 1 $68.05 $68.05 Link
                                Slave Cylinder 21526785966 FTE 1 $61.78 $61.78 Link
                                Guide Sleeve 23117512866 Getrag 1 $63.99 $63.99 Link
                                Transmission Input Shaft Seal 23121228493 Corteco 1 $19.19 $19.19 Link
                                Transmission Output Shaft Seal 23121222769 Corteco 1 $10.59 $10.59 Link
                                Center Support Bearing 26121225071 SKF 1 $18.39 $18.39 Link
                                Transmission Mounts 22322282340 Rogue Engineering 1 $64.00 $64.00 Link
                                Selector Rod Joint 25117503525 Rogue Engineering 1 $69.00 $69.00 Link
                                Transmission Shift Shaft Seal 23127501582 Getrag 1 $17.69 $17.69 Link
                                Transmission Shift Bushing 25111222015 Uro Parts 1 $14.39 $14.39 Link
                                Transmission Shift Lever Carrier Bushing 25117507695 Uro Parts 2 $4.79 $9.58 Link Consider upgraded material
                                Shifter Bearing Cup 25111220600 Rein 1 $5.69 $5.69 Link
                                Shift Lever Carrier Bolt 25117529079 Genuine BMW 1 $5.99 $5.99 Link
                                Shift Rod Circlip 25117571899 Genuine BMW 2 $1.39 $2.78 Link
                                Transmission Fluid 83220309031 MTF-LT-2 2 $45.09 $90.18 Link
                                Clutch Fluid Castrol SRF DOT 4 brake fluid 1 $69.29 $69.29 Link
                                Driveshaft Centering Sleeve 26117526611 Genuine BMW 1 $8.29 $8.29 Link
                                Flex Disc 26112226527 Febi 1 $97.33 $97.33 Link
                                Flex Disc Bolts 26117635643 Genuine BMW 6 $4.91 $29.46 Link
                                Flex Disc Nuts 26127536563 Genuine BMW 6 $2.09 $12.54 Link
                                Exhaust Gasket 11627830668 HJS 2 $8.79 $17.58 Link OE comparable
                                Exhaust Nut 11621744323 Genuine BMW 6 $3.59 $21.54 Link
