Originally posted by Jimbo's M
Running hot
Originally posted by Jimbo's M View Post
Your motor couldn't care less about humidity/dew point. It's all about the ambient temp. 240F is oil. Water never goes past half.
Oil temp I'm fine with going up, I mean, that is why we pour 10W60 in these. Water temp is what had me worried.
Originally posted by cobra View PostI had weird overheating issues where it would creep up at medium speeds on hot days and once I replaced the fan clutch it never did it again
Originally posted by Tbonem3 View PostA new, well running coolant system will dip below middle when coasting on the freeway unless ambient temps are ridiculous.'04 LSB Coupe 6MT
All my money goes towards maintenance.
Originally posted by yhp2009 View Post
It would be interesting to see if changing out the radiator with new OE has any effect. Let us know if you do
Originally posted by rbg View PostIs nissen an oem for us?
No not Nissen. Modine only. Not that Nissen isn't quality brand, but Modine is original equip.
You'll want a new rad at that mileage/age anyway.
My car would go a little over 210 on 95+ days...
...until I bought a new oil cooler/linesLast edited by Tbonem3; 08-12-2021, 09:13 PM.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by Jimbo's M View PostWater never goes past half.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by Tbonem3 View PostNo not Nissen. Modine only. Not that Nissen isn't quality brand, but Modine is original equip.
Rein hoses are fine, but their o rings seem to not be great.
Get the rein hoses and swap out the o rings for the ones WOLFN8TR sells if you want better quality seals and cheaper hoses.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Originally posted by Obioban View PostI assume you used OE parts thus far? Including actual BMW branded water pump?
If so... time to do the rad.BMW / E46M Interior & Trim Restoration.
Ok, an update. Took my kiddo to school this morning - ambient temp 83F, warmed up the car to operating oil temp of ~210F and got on it. Pushed hard for about 5 minutes, couple of redline pulls from the lights, and generally driving in high rev range all the time. Water temp dead center, oil up to 220F. Appears to be working just fine. Puzzled.
I will pick him up from school at around 1:30pm today, when temps expected to be around 100F, so will post another update then.BMW / E46M Interior & Trim Restoration.
That's how it goes. A 100k stock m3 cooling system will work just fine... until it's hot or on track.
The Saleri might be the OE brand for BMW, I'm not sure. Is it a composite propeller? It'll prob be fine. If bought from FCP, you could return it, add a little cash, and get an OE BMW.
K - Conti was the OE for hoses/bbelts, now "CRP" aka Rein liek Heinz said. They're good enough, but oring upgrade is suggested. The o-rings, unused, were flatter than my old genuine ones lolDD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Okay... All I stated is that mine doesn't.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
