Update on cases and cables for the first batch? I installed (one of) mine in the E39 and am having reception issues with an iPhone XR, which I suspect is due to the shipping box and antistatic bag temporary installation! Loving it otherwise though, except it makes it obvious that I need to upgrade the crappy DSP audio in that car ...
Most have already shipped, the rest will go out this week. Your reception issues will 100% be resolved by removing it from the anti-static bag -- that kills reception.
The DSP amplifier, when used in conjunction with the coaxial digital input cable produces REALLY good audio quality. If you're using analog, consider buying the $23 coax instead of upgrading the sound system .
Recently tested a BlueBus when demoing it for EAG (yes, THAT EAG. They are local :]) in an E39 M5 and was once again blown away by how much better digital sounds over analog AND how much better the E39 sound system is than our E46s
-Ted
Hi Ted, thanks! What I really meant re: DSP sound quality is the quality of the speakers that come on the non-M audio cars .. paper cones that are probably similar to those in the E46. The M-audio cars are supposedly much better (you can tell if it has two big subs at the top of the trunk) though I’ve never heard one. I agree that the DSP amplifier is perfectly good and won’t be upgrading mine, just the speakers to the Bavsound kit.
Oddly enough I’ve had two E46 non-M sedans in the past and was always pretty impressed with the Harmon Kardon audio on those compared to both my M3 and M5.
-Ted
Slight off topic, but do you know if the e39 M5 DSP amplifier can be retrofit into the e46? This would be a nice upgrade!
BTW I had to turn up the gain on my mic to about +21db for it to be clear. Is this normal?
I've had to do the same (actually turned it up to +36db which is the max) and I'm using the stock mic. If someone calls me, they say it's still sounds a bit low. I did update to the latest firmware and that did increase the quality substantially. BTW, does anyone know what the Mic Bias option does?
Ted: The BlueBus is an incredible device, both as an idea and in its execution. It was easy to install and works incredibly well.
