Galaxy note 20 ultra connection issue.
Perhaps this should be on a phone forum. but i have more success here. I just installed my Bluebus. Works perfectly with an old Note 4. However, the Note 20 ultra will play but you cannot pause, stop, go to the next track and the meta data does not come over. It has the same problem on my Lexus Rx350 (2013). Its clearly the phone, not the bluebus. Has anyone else had this problem. any solutions? I have not had success on the Lexus forums.
Just to be complete. The Bluebus is in my 2003 E46 with a 2006 business head unit.
Thanks
That would be AVRCP not being available/open.Originally posted by slawless View PostGalaxy note 20 ultra connection issue.
Thanks
Can you go to Settings on the phone and search for "AVRCP"? What's it set to? Mine is on 1.5 and it works fine on my Pixel 3.
-Ted
Ted, today I received and installed the mic part number ending in 762. The plug and play went OK, but the caller hears their voice echo, not mine. Both of us use iPhone 12, and I'm using firmware .16. Have I overlooked something?Originally posted by t3ddftw View Post
It'll probably be a month, sadly. Send me an email.
Glad you got it! Go for 84316938762 off eBay. That's your most affordable bet, and many of us don't seem to experience a difference between PNs.
Thanks!
-Ted
Regards,
Steve
I received and installed my 762 from Ebay. It seems to work OK, but my wife on the other end gets that "echo" folks have talked about. Only echos her voice, not mine as well. FWIW, I'm using firmware 16. Is there a current fix, or do I need a different mic?Originally posted by t3ddftw View Post
Thanks!
-Ted
Thanks!
Steve
Can I have you follow this guide: https://github.com/tedsalmon/BlueBus...g-the-TerminalOriginally posted by BubbaTree View Post
Thanks!
Steve
Then run these two commands (each with an enter at the end):
bt cvc on
bt mgain c1
That should help a lot.
Thanks!
-Ted
Is there a preferred setting? My OnePlus 3 offers AVRCP V1.3 to V1.6. How about Audio CODEC? What about A2DP hardware offload?Originally posted by t3ddftw View PostThat would be AVRCP not being available/open.
-Ted
2004 325xi Touring
I followed your guide, and ran both commands in order, but don't see any change in the echo issue. You know I'm not a computer guy, so, it's possible that I didn't correctly finish any required "save" or "exit" keystrokes. If I missed something, let me know, and I'll have another go at it tomorrow.Originally posted by t3ddftw View Post
bt cvc on
bt mgain c1
Thanks!
-Ted
Thanks,
Steve
As long as it replied "OK" to each command, that should be it. How loud is the cabin audio on a call? Turning it too high can cause the echo.Originally posted by BubbaTree View Post
Thanks,
Steve
Are you placing the calls from FM/AM mode or Bluetooth mode?
Thanks!
-Ted
Ted, the system did reply OK to each command. I'm using Bluetooth to make and receive calls, but may have the cabin audio turned up too high. I'll work with that aspect and see how it goes. To confirm, the consensus is that the 762 mic is the way to go, right?Originally posted by t3ddftw View Post
Thanks!
-Ted
Thanks !
Steve
Yes, 762 works fineOriginally posted by BubbaTree View Post
Thanks !
Steve
-Ted
For AVRCP, 1.3 or 1.6 works. Basically, you need 1.3+ to make use of the metadata and playback features of the BlueBus.Originally posted by tabora View Post
I don't know what Audio Codecs your phone offers, but the BlueBus only supports AAC (better option) and SBC.
No idea what A2DP hardware offload means. A quick Google reveals that this is manufacturer specific and in most cases doesn't change anything.
Any updates on how new firmware announcements will be issued? Can somebody post a list to the latest download? Thanks!2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
Originally posted by duracellttu View PostAny updates on how new firmware announcements will be issued? Can somebody post a list to the latest download? Thanks!
