    Originally posted by netcsk View Post
    Ted,
    Is there any preference? I have a 338 installed but still have a 762 from when they weren't working all that well. If 762 is better, I'd swap. If not, I'll offer it up since I shouldn't need it.
    I think they're six of one and half a dozen of the other. I would invite you test both out, since swapping them is a pretty easy process .
    -Ted
    I had and tested both when I first installed my BlueBus. Couldn't tell the difference between them.
      t3ddftw
      Any news on when 1.1.17 will be released?
      I've read on M5Board that it will bring caller ID functionality. Is that limited to navigation-equipped cars or will the CD53 also have this?
      Btw, by now even my girlfriend –who was a little skeptical of me spending over $200 on a 'tiny box' from the USA– has said that the product is great. Needless to say I agree with her 😁
      Thanks!
      -Eduard
      2003 Stahlblau E46 320d Touring – 6MT
      2002 Schwarz II E46 325ti Compact – 5MT
        Originally posted by Der_Spanier View Post
        t3ddftw
        Thanks!
        -Eduard
        Eduard,
        It hasn't been written into CD53 UI yet, but I might before I release it. I wanted to fix some of the bugs reported on GitHub before finalizing 1.1.17, but in many cases, I'm waiting feedback from users. I've been working on some supply chain issues on the hardware side -- some of the parts on the bill of materials are unavailable for many months, so I've had to find suitable alternatives and in a couple of cases I have had to alter the design to accommodate the replacement part(s).
        To answer the question on _when_ I'll release 1.1.17 in its final iteration: before Christmas.
        Glad you AND the girlfriend are enjoying the BlueBus! I have been using a unit in my iT which has the CD53 (for now, a Nav retrofit is planned) and it has changed my mind in that I don't find the BlueBus to be a waste of time just because of the limitations of the single line UI.
        I do find the metadata scrolling a little annoying sometimes. Driving with the CD53 in the car is a different experience than watching the screen dance on my office desk :P
        Some changes I'll be making to the CD53 based on my "testing" are:
        * Add ability to clear MPG average. Am I missing something or is this not able to be reset through the IKE?
        * Add static metadata mode
        * Add "OBC" view (don't ask me what this will show yet. I have to think about it).
        Another bit of info -- ECS Tuning will be stocking 100 BlueBus units in February, so I won't be running any buys until they are nearly out of stock. This will give me time to focus on the software, too.
        -Ted
          Originally posted by BubbaTree View Post
          I'm still loving my BB in my '03 M3 vert, and have a couple of related questions. Searching doesn't show me that anyone has a battery drain proven to be related to this really neat unit. I'm still chasing a drain, and considering every potential cause. Next, what will I need to add a mic for the telephone? Meanwhile, I can't say enough good things about using the BlueBus in this old car!
          Thanks for the advice!
          I'm pretty sure the BB has nothing to do with the battery issue I mentioned earlier. I would like to try adding a mic for my 2003 vert that is prewired for telephone. I don't see any wires above the mirror where it looks like the mic, if I had one, would be placed. Help with getting the correct mic and any surgery I'll need to perform to make it work with BB?
          Thanks.
          Steve
            Thanks.
            Steve
            You might have to do some serious digging around. It's a black three pin connector that you're looking for.
            You have a little grill to the left of the reading lights, right?
            Thanks!
            -Ted
              Hi Ted, Please don't forget the CD54 in Germany :-)
                Are there any issues with it? If I recall, the UI should be the same as the CD53, no?
                -Ted
                  I cannot access the menu navigation, to adjust it I always do it on a BM54 first, adjust it and then put it in my car with CD54.
                  After disconnecting the battery, all settings are always gone.
                  I always activate the automatic locking. This is automatically activated after the battery has been disconnected. So I have to remove it, adjust it to the BM54, and install it again on the CD54.
                    That's rather odd... the BlueBus doesn't wipe Settings at all.
                    Can you send me a video of trying to access the Settings on the CD54?
                    These are not really available, so getting one for the bench would be a feat, unfortunately.
                    -Ted
                      I can send you a CD54 for your test
                      it can take a while, the convertible is in hibernation.
                      I sold the last Bluebus you sent me here. Do you have one for me quickly?
                        That would work! However, if you don't want to risk shipping it, some logging and videos should suffice.
                        What do you define as "quickly"? I have a prototype coming back from Australia, so that should be here... at some point
                        -Ted
                          Eduard,
                          Thanks for the –as always– very detailed infos! I didn't want to put pressure on you to release it, just curious since I saw your commit on Github for "Application 1.1.17" a few days ago.
                          Who would've known that a you owning a Touring would be so beneficial to the Bluebus development...
                          Honestly, the single line UI isn't that bad. Once you've used it a few times and memorised what each button does, it's pretty easy and intuitive. Most of the time I just leave it alone and let it play the music on my phone randomly. The MFL gives me all the control I need.
                          Agreed, I already mentioned this on this thread. One option for me would be to display "Bluetooth" and only scroll the metadata once or twice before reverting back to "Bluetooth" when a new song starts playing. That way you get the song info without the annoying constant scrolling.
                          -Ted
                          * You should be able to clear all OBC functions (average fuel consumption, speed...) through the OBC button on the left steering column stalk. Just press and hold for a few seconds until the displayed parameter is reset. It's so simple that I wouldn't bother bringing this functionality to the BB.
                          * Already given you my thoughts on metadata. The issue with leaving it on static is that some song titles are longer than 16 characters so it'd look weird on the screen.
                          * I guess coolant temperature? No idea, I am pretty satisfied with the OBC on the E46 as it is.
                          Thanks!
                          -Eduard
                            Thanks!
                            -Ted
                            Yes, that grill is there, but I didn't see any wires on first look - I'll have another go at it today. If it's there, which mic will I need, and should I expect it to plug/play with the .16 version of firmware I'm running? As always, thanks for your support.
                            Steve
                              -Ted
                              maybe a little faster than the last one :-)
                                Steve
                                I found the little bugger, hiding in plain sight! Three wire plug, as everyone said. Now, which mic is the best?
                                Thanks.
