CSL breather tube
    The two connectors (NORMA brand) that are at each end of the tube.
    Thanks, was being a tad coy with my question... 😁
      Originally posted by Fresh1179 View Post
      Gonna open this one back up. I’ve been running the OE configuration on my ‘06. Did we ever figure out if this would cause issues. CSL software. This has been killing me for a while because every time I look at it, I wonder if I have it all wrong…
      Hi - I know this thread has gone quiet, but wondering what is best practice here. I have a 2005 and will start with modified CSL software (Terra). If I simply use the OEM CSL vent hose, should I be doing anything else here?
        May need to plug the opening on the air rail. That's it.
          Thanks, what do folks do with the electronic valve sensor that plugged into the stock vent hose? Not sure where to tuck that away if I don't want to completely unhook it from the ECU
            You can zip tie it under the cowl area where you can't see it.
              Makes sense, thanks for the advice!
                is your snorkel oem or haimus? just saw on IG and looks good
                  The snorkel is OEM, I wanted the ability to run the flap, mainly just because it thought it was cool and something to do as well
                    wow! 110% effort.
                    I am debating canceling the karb snorkel and getting the haimus snorkel just because it looks more OEM. not sure i can cough up $1700-2000 more for OEM snorkel/flap
                      wow! 110% effort.
                      That is what I did since I was after the more OE look of the matte black plastic. Did a small write up here since it wasn't confirmed anywhere that they fit up together.
                      Anybody order from Karb somewhat recently? They're adding a 107 euro "fees" line item to the invoice. I don't have a line of communication with them, so I'm just asking here if that's normal. Maybe duties? Thanks
                      They fit up like they're designed for eachother, but the Haimus snorkel is definitely not Karb level quality, the finish is a bit meh and you'll need to source OEM bolts since the supplied hardware doesn't work with the Karb.
                        would you do the same karb/haimus setup again or karb snorkel?
                          Yep 100%, I much prefer the look and it's still a decent chunk cheaper.
                          To be clear the actual construction of the snorkel is quite good, mine just had a few imperfections in the surface finish since the paint on it is very soft. Eventually I'll repaint it and I'll be 100% satisfied.
