CSL breather tube
    The two connectors (NORMA brand) that are at each end of the tube.
    Thanks, was being a tad coy with my question... 😁
      Originally posted by Fresh1179 View Post
      Gonna open this one back up. I’ve been running the OE configuration on my ‘06. Did we ever figure out if this would cause issues. CSL software. This has been killing me for a while because every time I look at it, I wonder if I have it all wrong…
      Hi - I know this thread has gone quiet, but wondering what is best practice here. I have a 2005 and will start with modified CSL software (Terra). If I simply use the OEM CSL vent hose, should I be doing anything else here?
        May need to plug the opening on the air rail. That's it.
          Thanks, what do folks do with the electronic valve sensor that plugged into the stock vent hose? Not sure where to tuck that away if I don't want to completely unhook it from the ECU
            You can zip tie it under the cowl area where you can't see it.
              Makes sense, thanks for the advice!
                is your snorkel oem or haimus? just saw on IG and looks good
                  The snorkel is OEM, I wanted the ability to run the flap, mainly just because it thought it was cool and something to do as well
                    wow! 110% effort.
                    I am debating canceling the karb snorkel and getting the haimus snorkel just because it looks more OEM. not sure i can cough up $1700-2000 more for OEM snorkel/flap
                      wow! 110% effort.
                      That is what I did since I was after the more OE look of the matte black plastic. Did a small write up here since it wasn't confirmed anywhere that they fit up together.
                      Anybody order from Karb somewhat recently? They're adding a 107 euro "fees" line item to the invoice. I don't have a line of communication with them, so I'm just asking here if that's normal. Maybe duties? Thanks
                      They fit up like they're designed for eachother, but the Haimus snorkel is definitely not Karb level quality, the finish is a bit meh and you'll need to source OEM bolts since the supplied hardware doesn't work with the Karb.
                        would you do the same karb/haimus setup again or karb snorkel?
                          Yep 100%, I much prefer the look and it's still a decent chunk cheaper.
                          To be clear the actual construction of the snorkel is quite good, mine just had a few imperfections in the surface finish since the paint on it is very soft. Eventually I'll repaint it and I'll be 100% satisfied.
                            I created this account just to answer the initial question about what is the solenoid valve used for on the newer S54s PCV design.
                            This PCV newer design is to get vacuum from the air rail on low throttle / idle to suck gases from the engine crankcase towards the intake.
                            The electrically actuated valve is meant to pulse consistently to ensure the following:
                            1- Act like a pump (compressor with its pulsing mechanism)
                            2- Gases do not travel back to the air rail
                            3- Modulating the amount of "allowed" vacuum (20 inHg is alot for CCV)
                            4- Further reduce the emissions volume of the S54 engine to comply with newer regulatory bodies around emissions by tackling the idle/low throttle evacuation of gas scenario
                            Blow by is not the only issue here, many engines in good shape don't have enough blow by to make it worthwhile. The gases being evacuated in this scenario are oil vapor from heat and a little blow by residue from WOT application before you lift off throttle.
                            Cars that are not driven hard all the time still gunk up the S54 instake manifold, valves, chambers, etc. and this is a resolution to that issue.
                            In short, this is the additional security BMW put on low throttle / idle to secure constant evacuation of gases from the crankcase.
                            For heavy throttle, WOT, the connection between the CCV and the intake secure enough suction
                            Additionally for supercharged S54, this mechanism needs to either go away or get protected by a one way valve between the air rail and the valve to prevent boost from seeping into the crankcase (not a lot of boost can go there since the valve is still pulsating and modulating the pressure allowed to travel in both directions)
