Originally posted by Actuary
View Post
Side Finisher Rubber Replacement and Rear Side Window Trim Replacement
Not that I found when I took mine apart. There is, however, a very thin rubber gasket that is part of the aluminum trim that provides a sealing effect to the body; maybe yours is broken, or something in that particular area?Originally posted by throwinshapes View PostIs there anything other than the small foam piece (51717037260) under the "finisher" to replace? I have been annoyed by morning dew on the roof dripping down into my open window. I always assumed the finisher should be diverting this water?
I somehow got two pairs of these so if anyone wants to buy a set that is already stateside- lmk.
as for installation, that bracket is a real PITA. I had to not only use lube but pry the bracket up a bit to allow the rubber to slide through more easily- but i still had to bring out some plier to pull it through and marred it a bit. still happy with the result though2002 TiAg M3 Coupe (SMG to 6spd), 2003 Jet Black M5
If you still have the extra pair I'd love to grab them from you. I'm in Austin too.Originally posted by lemoose View PostI somehow got two pairs of these so if anyone wants to buy a set that is already stateside- lmk.
I did it differently, but on the inner surface of the aluminum trim there is a hash mark that you use to align the B-pillar "end" of the seal to the trim in order to ensure proper fit at that location. That said, pull off the adhesive how you see fit while maintaining alignment to that mark.Originally posted by gpoints View PostStupid question: ok, so I’m about to install mine using the soapy water method. How/when do you pull off the adhesive tape covering once you get the seal shoved into the channel?
I am late to this party. I need a set. Is the deal still going? 🙏Originally posted by WOLFN8TR View Post
See Post #157
Group buy info
Price: $130 USD for one set. $260 USD for two sets. shipped to USA
Send paypal payment to: [email protected]
Under the payment amount it will ask you what this is for and type:
Group buy E46 Rear quarter weather stripping and include your name, full address including USA and phone number.
Still available?2003 E46 M3 TiAg/Cinnamon 6MT
2005 E46 330i ZHP Imola/Sand
Instagram:@thegenius46m
