    Originally posted by Actuary View Post
    Thanks for confirming
    No prob. Hope to see you and your m3 around Irvine. It's a sea of Teslas, rare to see another e46.
      Just placed an order. Thanks for the info guys.
        Is there anything other than the small foam piece (51717037260​) under the "finisher" to replace? I have been annoyed by morning dew on the roof dripping down into my open window. I always assumed the finisher should be diverting this water?
          Not that I found when I took mine apart. There is, however, a very thin rubber gasket that is part of the aluminum trim that provides a sealing effect to the body; maybe yours is broken, or something in that particular area?
            I somehow got two pairs of these so if anyone wants to buy a set that is already stateside- lmk.
            as for installation, that bracket is a real PITA. I had to not only use lube but pry the bracket up a bit to allow the rubber to slide through more easily- but i still had to bring out some plier to pull it through and marred it a bit. still happy with the result though
              If you still have the extra pair I'd love to grab them from you. I'm in Austin too.
                How times change... Irvine had to have been the E46 M3 capital when they came out!
                  Stupid question: ok, so I’m about to install mine using the soapy water method. How/when do you pull off the adhesive tape covering once you get the seal shoved into the channel?
                    I did it differently, but on the inner surface of the aluminum trim there is a hash mark that you use to align the B-pillar "end" of the seal to the trim in order to ensure proper fit at that location. That said, pull off the adhesive how you see fit while maintaining alignment to that mark.
                      Cool, thanks. Out of curiosity, which method did you use?
                        I drilled out the bracket rivet, installed the seal, re-riveted the bracket. Apparently the more difficult method.
                          See Post #157
                          Group buy info
                          Price: $130 USD for one set. $260 USD for two sets. shipped to USA
                          Send paypal payment to: matthewnavis@gmail.com
                          Under the payment amount it will ask you what this is for and type:
                          Group buy E46 Rear quarter weather stripping and include your name, full address including USA and phone number.
                          I am late to this party. I need a set. Is the deal still going? 🙏
                            Still available?
                            2003 E46 M3 TiAg/Cinnamon 6MT
                            2005 E46 330i ZHP Imola/Sand
                            Instagram:@thegenius46m
                              I would email Matt and see if he is still honoring the price
                              2007 Imola Red Z4M Coupe
                                Found the eBay listing and looks like they're available but now double the price. Also bmw jacked the price on the lower window rubber moulding underneath and they're $65 a side now! Bastards lol
                                Perfect Fit: Designed to fit all E46 COUPE models, ensuring a seamless fit and finish. Enhanced Driving Comfort: Experience reduced wind noise at higher speeds. The use of our original seals significantly minimizes disturbances, providing a quieter and more enjoyable driving experience.
