*** The datacenter where this server is so graciously hosted is going to be doing power maintenance. During this maintenance, I will be shutting down this server and nam3forum will be completely offline.
Start: 6/1/2024 12:00pm PST (Saturday around noon)
End: 6/2/2024 12:00pm PST (Sunday around noon)
So i received both sets i ordered. I probably wont install them any time soon. What is the best way to store these?
I'm assuming i should leave them in their plastic bags and laid out flat.
What are the other dimensions? It looks like maybe 1/8" thick and 3/4" or 7/8" wide?
1.5mm thick
22.5mm wide.
I bought some foam sealing tape from Amazon (20mm wide and 1.5mm thick), will do the job later this week. The Amazon foam is a little bit more dense than the OE BMW piece, but it should be fine.
Thanks. I was looking at those the other days, but just wasn't sure of the dimensions.
Just installed the trim with the Amazon foam. It works, but not as well as the OE because it doesn't compress as much making installation is a bit harder. I think the 1.0mm foam from Amazon would work better.
Lesson learned: re-use the foam that's on the trim. Don't mess with it. If part of it is torn or missing, buy the OE piece to replace what's missing. Or use the 1.0mm foam from Amazon to replace the entire piece.
So I sent payment to a “mateva” on Tuesday but haven’t gotten any confirmations yet, should I cancel it? Pretty sure I followed the instructions unless the price has gone up.
Patience, he probably needs a little time to process your order.
I don't think I got any confirmations either, just a shipped notice at some point and the item showing up a few days after that.
Only took about two weeks? But got them in. Maybe I missed the description in there, ordered 2 sets. Got two sets of two. Obviously don’t mind now I have a spare set which is great. Now I just need to pick a day to replace them.
Price: $130 USD for one set. $260 USD for two sets. shipped to USA
Send paypal payment to: matthewnavis@gmail.com
Under the payment amount it will ask you what this is for and type:
Group buy E46 Rear quarter weather stripping and include your name, full address including USA and phone number.
I'm really late to the party here. Is the $130 for one set both sides or just one side?
