Originally posted by EthanolTurbo
View Post
S54 Dyno Database
This is a sticky topic.
Ya, def a mechanical/timing issue going on there...power just looks down everywhere. It's also nosing over around 7,500rpms, and it should pull to 8,200+rpms no problem w/those mods. GL getting her sorted! I've been chasing similar issues w/mine, and 99.9% sure it's still somehow VANOS/timing related.Originally posted by ZiMMie View Post
Something is not right.
^what this guy said, no amount of tuning, elevation, gas etc is going to make your car down less than the guy with megan headers and lacking airbox
If I were you I'd check compression and do leakdown.2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
Lol the PO of my car installed a Lang stage 1 head and I just read all the posts about his work. Now I'm worried that there is something wrong with the head, but I guess I'll find out for sure once I have my car tuned next month and see how much power it puts down.
I just installed new cams and followers because of ticking and the followers wearing poorly. I'll probably get a compression and leakdown done as well. Going to open up the cover as well and make sure clearances are good and everything is wearing nicely.
Car has Karb airbox w/ CSL map sensor, 280/272 cams, ssv1 w/ 63.5mm catted/resonated section 1/2, stock section 3. Currently has a TTFS tune, but I feel like it should pull harder for the mods, but then again butt dyno can be deceiving. Going to have Hassan dyno tune at EAS sometime next month. I'll be happy with anything close to 350whp.Last edited by fullyflaredd; 07-11-2022, 10:39 PM.
I made 330 whp at EAS so with your setup you should do 360-380 whp easily.Originally posted by fullyflaredd View PostLol the PO of my car installed a Lang stage 1 head and I just read all the posts about his work. Now I'm worried that there is something wrong with the head, but I guess I'll find out for sure once I have my car tuned next month and see how much power it puts down.
Car has Karb airbox w/ CSL map sensor, 280/272 cams, ssv1 w/ 63.5mm catted/resonated section 1/2, stock section 3. Currently has a TTFS tune, but I feel like it should pull harder for the mods, but then again butt dyno can be deceiving. Going to have Hassan dyno tune at EAS sometime next month. I'll be happy with anything close to 350whp.Instagram: @logicalconclusion
Car was running pretty lean. Hassan added a little fuel there to be safe. There’s about a millisecond of a hesitation if burying the throttle 2-3k, otherwise buttery smooth.Originally posted by digger View Post
did he try to fix the issues at 2000-3400? that's not right and torque dip reflects that
Vanos rebuild along with rod bearings is planned for this winter.Originally posted by stash1 View PostThanx for posting up, and contributing to the dyno database! On a side note, graph looks great up to around 7K, then appears to flatten a bit? Have you checked your VANOS and/or cam timing lately?
