S54 Dyno Database
    S54 Dyno Database
    Ehhh, I haven't seen one started yet?, and I'm not the guy that's gonna do it...but we need another dyno thread!
    EDIT: Is everyone ok w/this being the official dyno thread moving forward?
    Ok, well, I guess that this will serve as the new Official Dyno Database-by default. All graphs are welcome, but plz try to include as much info. about your vehicle/mods as possible...so that others can use the info (as kind of a template) for their build(s). Also, when possible, plz try to include your pre-mod/pre-tune 'base' numbers to give folks an idea of the before and after results (delta). Please remember to try and not make comparisons from one type of dyno to the next, as they can vary up to 15% sometimes...hell, even the same dyno can vary a little from day to day based on temperature, strap tension, etc. There are a few different types/manufacturers of dyno's in use and not all are created equal. The 3 basic types of dyno's are: inertia (Dynojet), water-brake (or hydraulic dyno's), and electric or eddy current dyno's (Mustang). If dyno'ing on a Dynojet, plz try to get the operator to display the graph in SAE numbers. A lot of folks use STD. (which is fine), but STD. uses a correction factor of 60* vs. a correction factor of 77* for SAE. Granted, it's only about a 2.5% difference, but for the sake of the forum...it would be nice if we can just keep things as consistent as possible for everyone! Alright, let's get those graphs posted!
    Post those numbers up Stan!
    2004 Jet Black/Cinnamon 6spd ///M3
    Build///Journal
    IG: Khan_Art_
      Stash1, I recently saw this video of your M3 on Kassel's youtube channel and I was a bit surprised that it was making similar power to another M3 with headers and a stock airbox. Didn't you have a built motor with head work, cams, airbox, headers, etc.?
        Well here's mine from last April .
        Modifications:
        -CSL airbox ( custom)
        -280 272 Cat cams
        -Custom SSV2, modified for a bigger collector
        -Custom Section 1 2 and 3: oversized to 2.5 inch and en E9xM Xpipe
        -TMS pullies
        -Electric Fan
        -HTE performance Tune :P
        385.7whp 288.8 wtq :
        -280 272 Cat cams
        -TMS pullies
        -Electric Fan
        PM for performance Tunes
        IG: https://www.instagram.com/hte_performance_tuning/
          LMAO @ Stan being brutally honest!! I ain’t your guy..😂
          SICK Mr. Eido!!
            SICK Mr. Eido!!
            Well, I guess this thread could be the kick-off thread, we would just need to re-name it as 'The Official E46 Dyno Thread'.
              Yep, I had been struggling recently w/the car not feeling quite 100% and was having trans issues as well, so I took it up to see my buddy Matt Coyne @ Coyne Performance/Kassel to try and R&R the trans, and we threw it on the dyno while I was there to confirm my suspicions. Also, keep in mind that Kassel's dyno is a Mustang which reads a little lower in the first place, and when combined w/my sickly engine...well, the results were as expected. Working on getting it back to healthy now...and will update this thread or other dyno thread in the future!
              EDIT: Also wasn't aware that this video existed until a friend linked me to it-lol.
                Originally posted by stash1 View Post
                Yep, I had been struggling recently w/the car not feeling quite 100% and was having trans issues as well, so I took it up to see my buddy Matt Coyne @ Coyne Performance/Kassel to try and R&R the trans, and we through it on the dyno while I was there to confirm my suspicions. Also, keep in mind that Kassel's dyno is a Mustang which reads a little lower in the first place, and when combined w/my sickly engine...well, the results were as expected. Working on getting it back to healthy now...and will update this thread or other dyno thread in the future!
                Hopefully you are able to get it sorted out. It looks like a nice build. Is it still running a TTFS tune?
                Edit - Nevermind, I rewatched the video and it is still running a TTFS tune.
                  BW 64.5/66
                  flex fuel
                  TMS pulleys
                  exhaust cutout
                  (2) walbro 485 pumps
                  Kenne Bell boost a pump
                  ID 1000 injectors
                  rogue engineering surge tank and catch can
                  The intake manifold was cracked and not holding pressure at redline.
                    Modifications:
                    -280 272 Cat cams
                    -TMS pullies
                    -Electric Fan
                    Is that HP at the wheels? NM I watched the video. That's some awesome numbers!
                    E46 324i k24/dct/turbo Build Thread
                      4/12/2014 DynoJet in SAE
                      2004 E46 M3
                      6MT
                      55k miles
                      DynoJet
                      93 Octane
                      4 Gear Pulls
                      80~degrees
                      Modifications:
                      Active Autowerke headers
                      CPI filter
                      CPI RTX section 1
                      CPI X Stream section 2
                      OEM Muffler
                      TTFS IAT relocate kit
                      TTFS Custom Tune
                      BW intake elbow
                      KhanArt's E46 M3 Independent Dyno (DynoJet in SAE) - YouTube
                      Build///Journal
                      IG: Khan_Art_
                        Nice Z, thanx for adding to the "new" dyno database!
                          You ain't ready for the new new. We should race right now lol, I would most likely win 😂
                          Build///Journal
                          IG: Khan_Art_
                            Nice to see the forum back up and running Here's one I was impressed with at dyno the other day.
                            Stock Euro spec engine, stock intake with Eventuri and full Miltek exhaust system with decats. Normally the most i'd see from that setup would be 340HP with tuning. Definitely an out of the ordinary strong engine. Started out at 330hp on stock euro map, so 28HP gain from tuning.
                              Modifications:
                              -280 272 Cat cams
                              -TMS pullies
                              -Electric Fan
                              Those are fantastic numbers for N/A, I bet it's a lot of fun on the track
