Is my car running too cold, the needle is close to the first dot, sorry for the bad quality pic. This was highway driving. Outside temp was 61 according to the dash.
Running cold
There won't be much to bleed. Expansion tank is the highest point in the cooling system on our cars, so the system will self bleed.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
The coolant sensor under the intake manifold is what is reporting temp to that gauge. They can go bad and won't always throw an error code. It is much easier and not as messy to replace that sensor versus emptying most of the coolant to replace the thermostat. Once the sensor is ruled out, then time to move on to the thermostat.
That looks like oil drain to the sump. There’ll be a plastic hose entering the sump close to the dip stick tube, look for that and trace the loose end to where it’ll plug into that hole in your airbox.Originally posted by M3powerzz View PostJust change the coolant temp sensor. Now on the intake box, I see a small hole at the bottom. Is something suppose to be connected there?
Regards
