Originally posted by bmwfnatic
Diagnosing a new rear-end "popping" noise
Originally posted by bmwfnatic View PostYour entire rear left rear mount is pulling away from the car and not held in by much anymore, the next stage is for the panel to start cracking (as mine did), so to prevent further damage (which is much more difficult to repair compared to the stage it is in now, I would say it is somewhat urgent.
Originally posted by bigjae46 View PostI find it amazing how many "BMW specialist shops" that supposedly know all about M cars here in Houston still neglect the top side. One in particular had no clue as to what I was talking about. I guess us forum people aren't so stupid after all.
Originally posted by eisen View Post
Urgent probably wasn't the right choice of words on my part, more like "catastrophic". I'm definitely glad I caught it relatively early and am weighing my options for topside reinforcement as we speak. Sorry to hear about your troubles, too, but glad it's all squared away now!
Man, I couldn't agree more. The shops I've talked to about my wheelwell have been shocked and said they've never seen anything like it. This car has had multiple track inspections, too, and I'd hope any M oriented shop would check for common/obvious things like that prior to signing off on it, but I digress. Really, this whole thread showcases that I should've just been more diligent myself 😬.
First step is to cut out and inspect the top of the front mounts so you can assess the damage. Then clean up the seam sealer around the cracks and a little beyond the cracks you can see.
I know we talked about welding - you will have to MIG weld any cracks. A lot of that welding is upside down which is far more challenging. I would find a mobile welder to do that. Most of the work and cost is the prep work to expose clean metal. You can do most of that as part of inspecting and assessing the damage.
Great meeting you yesterday!
Great news for me, after this thread I thought I'd do the same inspection on mine after recalling that subtle "pop" sound over my left shoulder last time I drove it...I've got separation on driver side rear arch along the seam, though nothing visible inbound toward the actual rear mounting point with epoxied plates. I dont think I trust my welding skills on that thin edge, all I have is a TIG and it's been a while to jump back in upside down, so I'd really like to find out who you end up using for mobile as I'm in Houston as well.
So the popping is caused by RACP separation? Or did you also have loose axle bolts?
My subframe is fully reinforced top and bottom and wheel arch seam welded and I'm sure I have heard this popping every so often.
Plate install was done close to a decade ago, I don't have great documentation of the job unfortunately, though it wouldn't matter much as I only addressed directly at the mount points. There were not an abundance of cracks, just a few noticeable ones on that driver side IIRC. Now, today we realize I should have removed every ounce of coating to inspect, which I obviously did not.
E36 diff bushing that has been on the cover for at least the past 60k miles, still in good shape, not much more deflection than the new set in hand.
I'll accompany it with a photo of the noise that led me to get under there over a decade ago, so my fears were alleviated when I saw that it was just that 100lb diff slamming into the tunnel and not my RACP fully separatedFront bolt issue that presented itself again a few years later...but its still in tact, so we'll give it another go.
Side note, that front diff bolt drives me nuts. Mine seems to loosen after every track day and causes a lovely clunk. I finally ordered a Nordlock washer for it to see if that will keep it tight for longer than a couple months...
I'm currently frustrated as I can't decide which direction to go with fixing this...a fully disassembled vehicle on the quick jack and it's difficult enough to find the time to do the simple repairs I was tackling an hour here and there. Guessing the Vincebar or CMP option is at least a full day or two's effort?
I suppose its possible you had spot weld failures prior to reinforcement? What reinforcement kit did you go with?
I did, that's why I had it sorted. Had a reputable shop which does most of the E46 M3 RACPs in NZ fix mine too since I don't have much experience welding. I can't see any additional cracking but I also have yet to do a proper check. I'll check the axle bolts too.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
