S6-37 6mt swap info (broken off from junk yard thread)
    Nice. Yeah that's probably the simplest way to do it. I know there was some concern that the flywheel from a 330 wouldn't be well matched to an S54, but we're talking subtle stuff anyway at that point
      Originally posted by e46IX View Post
      FWIW I just slapped together a Z4M Roadster for a friend, with mix and match used parts.
      I used a ZF GS6-37 from an e46 330i, the Z4M shifter attaches directly to it.
      I used a flywheel from an e46 330i, and removed the pilot bearing from the S54 (330i flywheels have integrated pilot bearings)
      I used the clutch kit from the Z4M, and the starter from the Z4M (same as M3).
      Everything works mint, transmission engages and shifts like butter.
      I've had both clutch kits next to each other (330i and Z4M. They are virtually identical and all 3 clutch discs (e46 330i, e46 m3, z4m) have a 240mm diameter. There were some minor differences in the pressure plates between 330i and z4m but didn't cause any issues, car drives perfectly normal.
      I read that the input shafts have different lengths between the Z4M and 330i gearboxes. Does that not matter since you mixed and matched parts - mainly the location of the pilot bearing?
        Well done!
        Has your friend done any aggressive driving yet, shifting at redline? I've read reports of Z4M cars struggling with shifting at redline and that was attributed to the GS6 transmission as this was not an issue with E46 M3 with the 420G. Wondering if the GS6 from a 330i with the shorter input shaft exacerbates this issue even further?
        Another question - why did you choose to go with the Z4M clutch kit over the 330i one? Clearly it works and there's a chance it's slightly more capable of handling the S54 power but considering you used the 330i transmission and flywheel, 330i clutch would have been the safest bet which is why I'm wondering how you decided to go with the Z4M clutch assembly? Again, just curiosity in case there's something new to be learned as I love the GS6 transmission and plan to use it if I ever do an S54 swap on my E46 sedan.
        Cheers
          That’s why he had to use the 330 flywheel with the integrated bearing.
            Gotcha, so the Z4M has the longer input shaft as it has to reach the end of the crankshaft and the 330i is shorter since the bearing is on the flywheel. Now I'm curious why BMW wanted to use a specific flywheel for the M3 and Z4M rather than use the clutch assembly and transmission from the 330i in the Z4M.
              Originally posted by PetrolM3 View Post
              Well done!
              Cheers
              In my case it was just a question of what we had lying around, he bought the Z4MR as a lightly hit car that was being parted out, it was sold to us as a rolling shell with no powertrain and we put the car together on a budget with spare parts we had kicking around. I'll get him to report on how the car holds up to aggressive driving, give him a week or 2.
              Yes, the Z4M ZF GS6-37 does have a slightly longer input shaft than the 330i variant, the rest of the transmission is 100% identical (minus the shifter but that doesn't matter they can be swapped out for each other).
              I will be using the Z4M version of the GS6-37 for my personal E46 M3. It will be mated to the original S54 flywheel and a Z4M clutch kit. I got Ronald to sell me one of his 330i 6MT SSK.
              The only part I need to figure out next is the transmission cross brace, as I heard the cross brace for the ZF gearboxes interferes with the stock M3 mid-pipe. I'll see for myself once I'm putting everything together and decide what the best course of action is. Seems like most guys get an exhaust shop to modify the mid-pipe but personally i'd rather cut and well the transmission cross brace itself otherwise it will always be a headache to change exhaust components on the M3.
                As for the redline shift grind, yes its a real thing even on my own personal low-mileage (50,000 km's) M Coupe. I normally hesitate for a second going from 1st to 2nd on a redline WOT pull otherwise it will grind, can't just slam it into gear. Although to be honest I recently changed the trans mounts out for the Rogue Engineering solid rubber ones and I think there is some improvement there, I may try going to slightly stiffer engine mounts and see if limiting the movement in the drivetrain will help solve that grind.
                  Thanks for sharing, much appreciated!
                  There's another forum member on here who was looking to replace his 330i GS6 with a 420G and he was using a customer made cross brace - he recently posted in the classifieds looking to swap his GS6 with a 420G so it should be easy to find him if you want to see what his custom cross brace looks like, I'm sure he'll be happy to share.
                    Yeah it's a fair question. I think it just comes down to *technically* the dual mass flywheel should be relatively matched to the engine's characteristics. And I guess it was cheaper for them to make a few transmissions with a longer input shaft than making and perpetually stocking a Z4M-specific flywheel.
                    In my mind it should be feasible to build some sort of spacer that sits in the crankshaft and spaces out the pilot bearing to where it should be for the shorter inputshaft while using the S54 flywheel. But the machining would need to be spot on.
                      for which driveshaft to use, that is dictated by which rear differential you are using.
                      if you are running S54 and ZF 6speed transmission from e46 zhps and have the M3 3.62 diff in place then you use the M3 drive shaft.
                      if you are running S54 and ZF 6 speed transmission from e46 zhps and have the non M 3.07 differential, then you use the ZHP matching drive shaft that came with the transmission.
                      the difference is the input shaft on the diff, the M3 one is around 1.5 inches longer than the NON M one. if you put the M3 driveshaft next to the ZHP one, the M3 one is shorter to accommodate the longer m3 diff input flange
                      one one of my old previously sold S54 tourings had a S54 swap with the e46 ZF 6 speed transmission
                      in this picture i have 3 driveshafts.
                      left is e46 ZHP Auto trans
                      middle is e46 ZHP 6MT
                      right is e46 M3 6MT driveshaft
                      you can see the M3 DS is shorter than the ZHP 6MT one to make up for the longer input shaft flange on the 3.62 diff.
                      my final setup was:
                      S54
                      e46 ZF 6mt trans
                      e46 ZF 6mt clutch, Pressure Plate, Flywheel (for flywheel mounted pilot bearing)
                      e46 ZHP trans bracket
                      e46 M3 driveshaft
                      e46 M3 rear subframe with 3.62 differential
                      had no issues no vibrations or anything of the sort didn't have to make anything fit it all just bolted up and worked.
                      did have to do some coding in the M3 DME to remove the Gear position sensor and gear position sensor DTC codes similar to SMG to 6MT conversions. and on real m3s you will have to direct wire clutch switch to x60002 or take your GPS connector on the trans harness and short the wires together to complete the signal.
                        Little OT, but anyone know why the 330i/Z4, 330xi, and M3/Z4M use different clutch hardlines between the softline and the slave? That's 21526774230, 21526753015, and 21522229675 respectively.
                        Click image for larger version  Name:	1.jpg Views:	0 Size:	11.4 KB ID:	317785
                        Click image for larger version  Name:	2.jpg Views:	0 Size:	9.0 KB ID:	317786
                        Click image for larger version  Name:	3.jpg Views:	0 Size:	9.3 KB ID:	317787
                        If the M3 (420G) and Z4M (GS6-37) both use the same-P/N shortest-path hardline, and the hardline-to-transmission support bracket follows the trans (21526774227 and 21522229699,) and all cars use the same slave (21526785966,) then I think the hardline endpoints have to be in the same location in all configurations, so why do the non-S54 cars use different hardlines?
                        The softline is different for Z4s, but that makes sense since the length of the run differs with the chassis. Even the clutch pedals are the same across all E46s (35311163870). Is BMW controlling pedal feel and damping vibrations in the hardline? How could that work if it's well-bled - fluid volume? Bend radii producing resistance?
                        Thanks guys.​
                          I’ve had two Z4M, one brand new (2008) and one used (2006) and somehow my 2006 with 90k miles does not grind at all at high RPM. It’s a little crunchy at low revs on shifts because I’m not sure the fluid was ever changed before me but it somehow shifts far better at high RPM than my brand new 2008 car I had for 25k miles. My 2008 car would grind randomly on fast shifts into second with a strange buzz / zipper / drill noise and not actually end up in gear. I have never had that happen on the 2006 yet. If that buzzy grind is what you’re talking about, I wonder if some of these gearboxes are sort of defective. Had I known you could have one without that grind I’d have made BMW replace that trans under warranty.
                            The E9X M3 ZF box does the same thing on a really aggressive 1-2 shift. They just are not designed for this hard 1-2 shift you see in drags races and in F&F movies. Even automotive journalists grind second gear when try to get the fastest 0-60 times out of the test cars.
                            I have noticed that backhanding 2nd gear makes it a much smoother change if you want to give that a try.
                              I have zero problems with my new (older!) one. I actually can't reproduce it. My 2008 car would do it even on reasonably fast shifts. My shifting technique hasn't changed so I was shocked to find that some of these ZF boxes don't do it.
                                Permission to revive an old thread..
                                I've had the 330 ZF GS6-37 in the M3 for several years now with 330 Valeo Single Mass Flywheel Clutch kit and it's been great. Love the notchy-ness. Drives and shifts amazingly well.
                                The only issue I've had is the cross brace touching the midpipes.
                                I have had the cross member shaved off enough without structurally compromising it's strength and was able to clear it. Now the car runs an aftermarket exhaust and has slightly less clearance than the stock exhaust unfortunately. The midpipes expand with heat and slightly hit the cross member causing a slight vibration / metallic noise which is mostly audible during higher revs.
                                An idea I had recently was to use a bit of exhaust wrap in that section to reduce or possibly eliminate the vibration and noise.
                                Curious, what kind of solution did you come up with for your swap?
                                Regarding all the comments and questions around the potential grinding that can occur during aggressive 1st to 2nd shifts:
                                I did notice some grinding when aggressively shifting from 1-2 in the early days of the swap. It's been a long time since i've had that happen ever since I slightly adjusted the ZHP shift knob and angled it toward the driver seat. Once I seated knob toward the driver seat and made sure to always shift 1-2 against the wall, it's never been a problem. This is with a UUC 330 SSK, which i'm honestly not a huge fan of. I run Motul Competition gear oil in the transmission. Just make sure to take it easy when its cold from 1-2. Autosolutions will probably be my next upgrade since the UUC SSK is very mediocre at best.
