What happened to injector prices?
    Has anyone else noticed the extreme price hike on injectors?
    I have had a misfire I’ve been trying to diagnose, and troubleshooting has pointed me towards it possibly being an injector on its way out. I went to look them up on FCP and they are now ~360 each for BMW injectors, and the bosche injectors now seem to be NLA.
    I Replaced an injector back in 2021 and they were only 41$ for the Bosche part. Seems kind of crazy that for a full set of injectors were now looking at > 2100$.
    Anyone know of some injectors from another platform that may work? There are some deatschwerk 440’s that should work, and are ‘only’ 460$ for a set of 6, but those require tuning to be used.
    Is this what we’re doing now? Hopefully we can brainstorm a better alternative.
    2003 Stahl Grau on Imola Red E46 M3 / 1992 Brilliatnrot E30 318iC Vert
    @ JT_E30
    Have yours rebuilt.
    2005 BMW ///M3
      Quick search should reveal a history of the price increase(s) and various other options to augment OEM injectors should you need to.
      My car has been in the shop going on close to two months now. I had them put on a smaller pulley on my supercharger, and swap my injectors and fuel pump for bigger units. ID1050x to be exact. They haven't been able to get my injectors to seal properly yet. At first, they weren't sealing at all. So they sent the adapters to a
      2006 Silber Grau Metalizat ZCP 6 MT M-texture (F2AT) - Turner CSL V2/Schrick 280 272/SSv1/SS Sec1/Sec2 dual res/SCZA TI (raw) - FatCat stage 3 ult 400f/784r - EC7r 18x9.5 ET35/CRS 275/35/18 - RacingBrake BBK/MileEnd CSL bumper/Vorsteiner Trunk/Cobra Nogaro Circuit Mtexture/GC RCA/YURKan Cages/Hotchkiss/Vibra-technics/
        This is just a post to hopefully help a few others out. I had a really odd cold start misfire which would sometimes clear once driven. I code read the car and it came up with an injector 2 fault. I set about swapping injector 1 and 2 over to see if the fault moved with it. Sure enough it had...
        Seems a pretty close match in specs which should be handled by fuel trims.
          Originally posted by Shonky View Post
          https://forums.m3cutters.co.uk/threa...tinued.262432/
          £300 for a set rather than each is a bonus too.
            I noticed his myself recently, I went to go change out the injectors on my X5 and prices have also skyrocketed... I'm looking at $3700 for 8 injectors.
            Unfortunately I don't think there's a cheap alternative like there is for the S54.
            2004 Dinan S3-R M3
            2012 Dinan S1 X5M
              Yeah it's become f'ing ridiculous. I don't know what F BMW is thinking and no one is also not rebuilding these index whatever injectors…
                I believe Stryker Performance rebuilds them.
                Instagram: @logicalconclusion
                  Yeah I remember them after checking out the site, do you know anyone who has used them for the E70 X5M/N55 injectors rebuild etc?
                    So I have no idea where I got this spreadsheet, but the information seems specific enough that I suspect it is real Bosch injector data
                    E46 M3 injector below:
                    Injector type OE NR. Type Info production stop
                    (status 01.2008)
                    offer drawing Resistance (Ohm) Test medium Operating pressure (kPa) Q-stat (at operating pressure) (g/min) Q-stat with 300 kPa (g/min) Q-stat with 300 kPa (ml/min) q-dyn with 300 kPa, ti 2,5 ms (g/1000 Imp.) Spray type Spray angle alfa-50
                    (for 2 beam)
                    Spray angle alfa-80
                    (for cone-characteristic)
                    axial deviation angle (spray bent angle) Spray orientation angle Spray distribution (area, spray amount) allowed fuels Version, type Electrical connector locating lug (anti rotation device) hydr. connection to manifold hydr. connection to fuel rail Distance between O-rings
                    (O-Ring to O-Ring)
                    Total length
                    0280156052 0 280 156 052 EV 6 A 280 434 251-114 12 Heptan 400 223 193.1 276 6.32 E 15° ¤ 10° 270° >30% E85 Design 96 Jetronic no O-ring variant O-Ring standard 48.4 61
                    These 3 below all flow very slightly less, but seem close enough otherwise that they'd probably be plug and play without retuning and letting adaptions do their thing
                    (status 01.2008)
                    (for 2 beam)
                    Spray angle alfa-80
                    (O-Ring to O-Ring)
                    Total length
                    0280156066 0 280 156 066 EV 6 12 Heptan 400 219 189.7 271 5.63 E 15° ¤ 10° 270° >45% E85 Design 96 Jetronic no O-Ring standard O-Ring standard 48.4 61
                    0280156070 0 280 156 071 EV 6 12 Heptan 400 219 189.7 271 5.63 E 15° ¤ 10° 270° >40% E85 Design 96 Jetronic no O-Ring standard O-Ring standard 48.4 61
                    0280156071 0 280 156 071 EV 6 12 Heptan 400 219 189.7 271 5.63 E 15° ¤ 10° 270° >40% E85 Design 96 Jetronic no O-Ring standard O-Ring standard 48.4 61
                    Those all seem to be used on some lower end VWs, though probably not US models since I'm not seeing them carried at the usual sources.
                    The ones below flow more, but may be reasonable options with a minor tune adjustment
                    (status 01.2008)
                    (for 2 beam)
                    Spray angle alfa-80
                    (O-Ring to O-Ring)
                    Total length
                    0280156061 0 280 156 062 EV 6 12 Heptan 300 217 217 310 6.9 E 15° ¤ 10° 270° >45% E85 Design 96 Jetronic no O-Ring standard O-Ring standard 48.4 61
                    0280156062 0 280 156 062 EV 6 12 Heptan 300 217 217 310 6.9 E 15° ¤ 10° 270° >45% E85 Design 96 Jetronic no O-Ring standard O-Ring standard 48.4 61
                    0280156142 0 280 156 143 EV 6 12 Heptan 300 217 217 310 6.9 E 15° ¤ 10° 270° >45% E85 Design 96 Jetronic no O-Ring standard O-Ring standard 48.4 61
                    0280156143 0 280 156 143 EV 6 12 Heptan 300 217 217 310 6.9 E 15° ¤ 10° 270° >45% E85 Design 96 Jetronic no O-Ring standard O-Ring standard 48.4 61
                    0280156063 0 280 156 064 EV 6 12 Heptan 300 269 269 384 8.5 E 15° ¤ 10° 270° >45% E85 Design 96 Jetronic no O-Ring standard O-Ring standard 48.4 61
                    0280156064 0 280 156 064 EV 6 12 Heptan 300 269 269 384 8.5 E 15° ¤ 10° 270° >45% E85 Design 96 Jetronic no O-Ring standard O-Ring standard 48.4 61
                    I don't know enough about injectors to say for sure whether we can deviate on spray angles and how much room we have to mess with the length.
                      I dont but those are the same injectors as N54 and those guys are using them. Haven't heard anything.
                        Great info Terra, Where did you find the detailed information?
                        All i could find was the following:
                        BOSCH NUMBER LBS/HR CC/MIN GRAMS PSI Bar Impedance Static flow rate at 3 bar, medium N-Heptane [g/min]: Notes
                        0-280-156-052 23.5 247 177.7 43.5 3 12 193 OEM E46 M3 S54
                        0-280-156-061 30.15 316.9 227.9 43.5 3 12 217
                        0-280-156-063 33 346.8 249.5 - - 12 269
                        0-280-156-065 26.85 282.2 203 43.5 3 12 189.7 E46 M3 S54 Alternative
                        0-280-156-070 26.85 282.2 203 43.5 3 12 189.7
                        There is a guy in the UK using the 065's and he is happy with them. See post 5
                        Are the 052's and 065's available in ​the States?
                          Cleaning/rebuilding is not hard (even DIYable, although a bit more expensive to flow test) and parts to do so are fairly cheap. Unless the electrical portion is open circuit or something they're usually rebuildable.
                          Already rebuilt sets seem to be available from around $200-250 USD in quite a few places
                          Why the need to buy new? Sure it's nice to have the option but it doesn't seem like it's a completely unobtainable part (yet).
                          Also this is a good reference for part numbers - data matches the post above:
                            What happened to that guy who charged like $60 to rebuild and flow test? I'd gladly pay him $100 to do it. He was quick and those injectors are still working fine 7 years later.
                            But who is everyone using for rebuilds nowadays?
                              If you're referring to a person with screen name "Mepeh" it seems he dropped off the face of the earth. I texted, called his cell, and also emailed in 2019 but no reply.
