What happened to injector prices?
    That is not a rebuild, just cleaning and testing, that is why I ask.
      There’s a part where he can replace the screens…is that not rebuilding?
        IMO anything over 100k replace
          Any particular reason for that?
          The whole reason I got into cleaning injectors is because my Blackstone analysis kept showing fuel in my oil samples. I wanted to replace my injectors as well till I looked into cleaning and rebuilding stock injectors. I had two injectors that were dripping when off, after cleaning, replacing screens and retesting, they work just like new. No need to throw money away.
            Found the seal kit at Rock Auto for $1.80 per injector
            Confirmed fit on their site. You can also send them in for a rebuild (through Rock Auto) for $34 https://www.rockauto.com/en/moreinfo...&pt=6224&jsn=8
            @gheorghe Can you provide same such service? Rather ship to NC than Cali
ID:	251657​ Click image for larger version
            This kit includes the filter and pintle cap: https://www.ebay.com/itm/29368651674...r=592496285930
              Pintle cap replacements depend on the injector, EV6's typically do not have caps. A rebuild for these is the internal filter and the O-rings.
                I just had gheorghe perform a cleaning and rebuild for me. He’s extremely reliable and prompt.
                My injectors were flowing well before cleaning and rebuild - and He was able to get another 3% out of them.
                  Reviving this thread.
                  I bought this item :
                  Listing clearly shows that it is Bosch P/N 0 280 156 052 which is the correct one for the S54 engine.
                  I have received the injectors, and the Bosch P/N is scratched off. I believe they are 0 280 156 029.
                  I measured the resistance of one of them, and got 15Ω, which is close to the 14.5Ω of the 0 280 156 029 and not the 12Ω of the correct ones.
                  0 280 156 052: 193 g/min, 12 Ω <- Correct one
                  0 280 156 029: 150.7 g/min, 14.5 Ω​
                  I have contacted the seller, but what could lead them to sell them as correct injectors for this engine ? Can they change the specs ? Seems fishy to me.
                  Edit : adding some pictures
                  2004 E46 M3 • TiAG / LSB nappa
                    They ripped you off or sent the wrong ones.
                      I have contacted them, I'll report back here with their answer.
                      But clearly, those are the wrong injectors.
                        I have these in my car currently. I’ve been trying to track down a no start issue. Well rather it requires one attempted start and then usually fires up on the second crank. Rich codes. Sometimes finicky idle. Once’s it’s driving its butter and fuel economy is very good.
                        Replaced MAF, fuel pump and associated parts, etc.
                        Has an HTE tune. Hassan seems to think it’s potentially a latency difference, or vacuum leak from the injector o-rings not sealing properly.
                        Another member stated it seems that the injectors linked are not exact but very close. 263.8 cc per minute where as the factory injectors are 268.4 cc per minute. Could that make a genuine difference like this but only on startup or idle?
                          Well, what is the exact BOSCH SKU that you have ?
                          As those vendors seem to just ship to you whatever they have in stock.
                            I’ve noticed that in other threads and such. Based on the paperwork I have they are Bosch Part # 0280156065.
                            I inherited this when I bought the car a few weeks ago so I’ve not yet pulled them out to look for myself but I will in a day or two.
                              https://www.ebay.com/itm/28356536326...EAAOSwEExdQJ~-
                              Is your no-start every time? I have an intermittent no-start I've been chasing for years, with every possible fuel component and sensor replaced. But it's more of a once in a while issue rather than a daily one.
                                Every single start. 90% of the time I can crank it for a 2 seconds, immediately of/on again and it’ll start fine. Hardly ever hesitation on the second crank.
                                The longer it sits, the more cycles it’ll take to start.
