Turner CSL style airbox, pros and cons?
    ... Also wondering if the juice is worth the squeeze.
    Installing a Turner CSL Style box with headers and high flow catalysts with all the other things plus tuning is a $6K project. It has not improved my track times, but it looks and sounds cool.
    My only concern with the Turner product is that there are gaps between the carbon intake and the edges of the filter that allow a minor amount of unfiltered air to flow through the engine. Furthermore, the pins that hold the two intake pieces together on the bottom are not durable. I have one that is broken already, and this is important to keep the filter firmly in place. Had I been involved in designing the product I would have asked for more clearance between the intake and the strut tower, and that doesn't seem like a big ask.
      IMHO, the Turner box is good if you're trying to budget this.
      That being said, Karbonius boxes have their own issues very much like EVERY CSL airbox rep has had.
      So is that worth it? Completely up to you.
      Having been in a real CSL and ripping on it, I can tell you the OE CSL setup sounds nuts on an actual CSL. Hearing the OE box on a standard car is much much different.
      2005 BMW ///M3
      Black6MT Daily
        A large part of this is probably the reduced sound deadening on the CSL.
        Edit: ah plus headers etc if you have a US spec car.
          For what its worth, I've had my TMS V2 CSL Airbox installed for over a year and a half with no issues. Build quality is good, just not a fan of the trumpet design, but I understand why its designed the way that it is. Cant go wrong if you're on a budget imo
          2003.5 BMW M3 Carbon Schwarz Metallic/Cinnamon 6 Speed – HTE Tuning | Kassel CSL DME | AA Headers | AA Section 1 | SS Resonated Section 2 | SS Race Section 3 | TMS V2 CSL Airbox | TMS Street Plates | Ohlin’s R&T Coilovers | Ground Control Front and Rear Sways | Ground Control Adjustable Camber Arms | DMG Autosport Pro46R | FreakyParts BBK Front | Porsche 996 Conversion Rear | CMP Stage 1 + 1.5 Reinforcement Plates | CMP Subframe Bushings | CMP RTAB’s | Euro Bumper | SGT CSL Trunk | Dr VANOS
            Curious if you did anything else to complement the airbox? Tune, headers, etc.?
              And cams.
                Hey JokerElite I have AA headers, AA section 1 with a SS resonated section 2 and SS Race section 3. The car has an HTE tune. I really wanted to go SS headers - back, but if I recall correctly I bought the majority of these parts during the pandemic and either the prices were outrageous or the wait time was insane. I also thought about going with euro headers, but I had the hardest time trying to find a set at the time. Oh well
                  I have one on my car. No issues with it. Installed in a couple hours, the hardest part was getting the stock intake off. Looks great, sounds fantastic, fits well. Snorkels are cool I guess, but there's no strict need for it.
                  If you are really worried about 'hot air intake,' you can buy just the Eventuri insert that directs air up from the fog light area. That said, I live in hot-as-hell-houston and havent felt any loss in power from heat.
                    I heard the V1 had some quality issues. I have the TMS V2 and like others have said - I've had no issues so far *knocks on wood*. I think any issues you'd run into would likely be associated with whatever tune you go with moreso than fitment or quality. The shape is different, but I like it. My wife says it's looks like a tuba, but people are cars & coffees love it and always try to look inside. The sound is amazing (especially when I was running a gutted rear interior). Airbox + Euro headers/cats alone is good for around 330 whp with a tune from Hassan.
                      Originally posted by jdamore44 View Post
                      This is where I'm at. The headacheless idea of the Stock Carbon Box is tempting. I like the idea of running MAF for road trips.
                      Smog aside, if you convert to a MAP sensor and the CSL programming the car runs just like stock. Mine does! Same MPG, no problems with elevation, hot or cold, and runs just like stock.
                        Can you give me a breakdown of your exact setup? TBH I’ve heard a lot and seen a lot of threads about reliability and drivability issues. If there’s like a known setup that definitely works, I might be swayed in the future when the time is right money wise.
                        '01 M3, Imola/black
                          I have both. As much as I was a proponent of the Karb MAF + Eventuri, the reality is that they sound different, the tone and volume are different. Is like hearing two singers sing the same song.
                            Do airbox, MAP and Bryson mullet tune. Closest thing to stock drivability wise.
                              I have probably $50 into my setup...this isn't a how-to but just a rough idea of what I did. All the information I used is here on nam3.
                              IAT sensor:
                              IAT temp sensor: https://www.fcpeuro.com/products/bmw...or-13621739510
                              clip: https://www.fcpeuro.com/products/bmw...ng-12521427615
                              2 wires: https://www.fcpeuro.com/products/bmw...ct-61130005197
                              Protective cover: https://www.fcpeuro.com/products/bmw...ol-12521732635
                              MAP sensor:
                              I used a Bosch 0261230101 sensor (same scaling as the OEM CSL map sensor)
                              No idea why it's listed as a saab knock sensor, but it's a MAP sensor. I don't remember where I bought the plug, I think I found it on ebay but it was only a few bucks.
                              The MAP sensor gets wired into a PIN on the DME that currently has no pin, so you just add it in. I put a T into the brake booster hose for an air source for the MAP sensor, but you can get fancy and get the kressel or OEM BMW CSL style mount too - but whatever either works just fine. The IAT wiring is currently part of the stock MAF, so I used a deutsch connector so I can swap between the MAF and just IAT cleanly.
                              As for the code, I used Terra's modified CSL programming for a standard mss54hp ecu. You can get it here: https://github.com/saildot4k/MSS54-X...4HP%20to%20CSL
                              So on the programming side (for more details, dig around in the coding section here) but the short tl;dr; is
                              1) Use MSSFlasher to backup your DME (programming AND tune)
                              2) Flash the full TerraCSL programming to your DME
                              3) Then READ the partial program so you can modify it
                              I used TunerPro to modified the cams profile (I don't have CSL cams)
                              I used ECUWORX to make the tune a manual (no smg) and anything else you want to do at the same time
                              4) Flash the new modified partial tune back.
                              At this point, the car should start and run! I did my own tuning, and this was extremely helpful https://nam3forum.com/forums/forum/s...or-drivability , but there are bunches of people/companies that can do the tuning side of things on a dyno and/or street driving. Whatever you're comfortable with.
                              All in all, it cost me about $50, car runs great, passes Oregon DEQ (smog), no check engine lights.
                                I've been running a CSL MAP sensor, CSL rail, CSL software and a Bimmerworld CF box since 2013. Approximately 25k miles. Car has been run in SC summer heat and VA winter cold. Never had an issue.
                                Mike
                                02 M3 Titanium Silver / Black
                                11 Tundra SuperWhite / Black
