Originally posted by heinzboehmer
CSL MAP Sensor Solutions
Ah I'd forgotten the Kassel solution sits right by the TBs - great call.2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats/CSL airbox/CSL console/6 point RACP brace/Apex ARC-8s
On my car the Kassel location did create "waves" on the datalog as compared to the COVID sensor location that was more or less a continuous line.
That said, when even light throttle input was introduced the waves smoothed out. I did contact Kassel about this, they were apparently fully aware of this fact an said it was not anything to be concerned with.
Side note, I really need to try this Mullet tune!
Post 71 shows what what my vehicle did, others also had data posted.
I know I have already asked this in other threads and you guys probably rolling your eyes, but I just am not 100% that I've got this figured out. I am trying wire a MAP sensor via a connector made by Kassel. I have called Kassel and their response is "the wiring is factory CSL". Well I do not have a factory CSL2004 Silbergrau Metallic 6MT
Nice, I remember that thread. Kassel kit didn't seem to affect how the car drove much at all until I got on an tune that is actually optimized (mullet).Originally posted by Cubieman View PostOn my car the Kassel location did create "waves" on the datalog as compared to the COVID sensor location that was more or less a continuous line.
https://nam3forum.com/forums/forum/m...p-please/page5
There were clear drivability issues at very small relative openings and steady throttle pedal inputs that went away when I swapped to the OE CSL rail. You can see the pulses in the readings at low throttle here: https://nam3forum.com/forums/forum/m...9010#post29010
So, data seems to coincide with observations on this.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Oh man! I hadn't seen those comparisons before heinzboehmer that's a huge effect!Originally posted by heinzboehmer View Post
The MAP sensor AD is read every 1ms and the MAP sensor RF calculations are every 10ms, so it's not surprising that it had a noticeable effect for you!
For others who are wondering, the reason why I say that, and the reason you probably haven't noticed this effect if you're not on the Mullet Tune is due to two reasons:
1: The MAP sensor based RF calculation is tuned for the CSL. This needs to be adjusted for cars with M3 cams. If this is not done then it is chasing the wrong RF, and hence fueling. The end result is the MAP sensor correction factor tends to saturate to one of its two limits.
2: If you have M3 cams the VE map is so off in most CSL-based tunes anyway that you don't notice #1 anyhow.
The Mullet tune addresses both of these things, hence it becomes very apparent when your MAP sensor is screwy in any way. (As an aside, MAP sensor DTCs don't throw a CEL. I'm fairly confident there'll be a number of people out there who believe they're running a MAP sensor, who are actually effectively running Alpha-N because their MAP sensor has silently thrown a code).2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats/CSL airbox/CSL console/6 point RACP brace/Apex ARC-8s
Out of curiosity, do you know offhand what code number and/or description that would be?Originally posted by karter16 View Post(As an aside, MAP sensor DTCs don't throw a CEL. I'm fairly confident there'll be a number of people out there who believe they're running a MAP sensor, who are actually effectively running Alpha-N because their MAP sensor has silently thrown a code).
Yep! Pulses are crazy. What was originally hidden by a combination of (1) + (2) became pretty apparent once the rest of the tune got dialed in.Originally posted by karter16 View Post
Fortunately Bry5on is using the brake booster adapter, otherwise he would have probably been chasing his tail for a while with this.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
- Likes 3
Yep:Originally posted by elbert View Post
Out of curiosity, do you know offhand what code number and/or description that would be?223 0xDF pressure intake manifold Charge-air pressure sensor, range check 2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats/CSL airbox/CSL console/6 point RACP brace/Apex ARC-8s
