Im searching for some right now. What’s the shops name?
Porsche Brembo 996 BBK conversion
Hoerr RacingOriginally posted by Mattn1192 View PostIm searching for some right now. What’s the shops name?
I need an answer here too, I'm using DS2500 and they are INSANELY loud and horrible. I don't know if I'm missing some magic trick here to get them to even shut up a little bit.Originally posted by Thonas View PostSo I’m coming back to the well again to see if anyone has any tips or tricks to eliminate or reduce front brake squeal when the brakes are hot (zero noise when cold). It is so loud that you cannot hear the radio and everyone stops to look to see where the horrible noise is coming from. I also have a Macan turbo which was referenced in the Porsche bulletin that was shared in this thread and the two sequels are worlds apart in both tone and volume with the Macan being very tolerable and in no way a nuisance. Thanks!
I have done,
-new shims
-coated all metal on metal pad to caliper surfaces with anti squeal coating
-moved from stock brembo pads to akebono ceramic pads (which claim zero noise)
I’m almost ready to go back to stock. This mod makes me hate to drive this car.Originally posted by chapmans View Post
Okay….. I did the following;Originally posted by Ag09243 View PostI had squeaking issues too but I removed the shims and added break lube to the back of the break pads where the pistons make contact and the squeaking stopped. Hope this helps.
-removed pads
-removed shims
-applied anti- squeal lube to the back of the pads, allowing it to dry for 48 hours
-applied BG anti-squeal to the pads
Then I gave it a good test drive and as soon as the brakes got hot, Squeal city.
Does anyone know if this can be caused by a problem in the calipers? Pistons etc. I have never seen or had brakes make this much noise (excluding race pads).
I know it sounds crazy, but check to see if the edge of your rotors are rubbing on the calipers when they get hot … check the calipers to see if any paint has rubbed off. You might need to add spacers to the brackets to get some additional clearance.
Any reason to not try OE Textar or ATE pads? Yeah I get it they have more brake dust but historically they have no squeal issues.Originally posted by Thonas View Post
-removed pads
-removed shims
Does anyone know if this can be caused by a problem in the calipers? Pistons etc. I have never seen or had brakes make this much noise (excluding race pads).2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
I checked. It close but has not touched.Originally posted by DvSkD4 View PostI know it sounds crazy, but check to see if the edge of your rotors are rubbing on the calipers when they get hot … check the calipers to see if any paint has rubbed off. You might need to add spacers to the brackets to get some additional clearance.
Stock Brembo and Akebono are neither ATE nor Textar. So I ask again, why not use OE Porsche pads?Originally posted by Thonas View Post
I tried both stock Brembos and Akebono Brake Pads. Same result.2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
If you are using CSL rotors front and rear the use TEX-2193702 and TEX-2332902 pads for front and rear. Both available on FCP Euro.Originally posted by Thonas View Post
Do you happen to know the part number for those pads? Thanks2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
