    Im searching for some right now. What’s the shops name?
      Hoerr Racing
        Thanks bro
          Originally posted by Thonas View Post
          So I’m coming back to the well again to see if anyone has any tips or tricks to eliminate or reduce front brake squeal when the brakes are hot (zero noise when cold). It is so loud that you cannot hear the radio and everyone stops to look to see where the horrible noise is coming from. I also have a Macan turbo which was referenced in the Porsche bulletin that was shared in this thread and the two sequels are worlds apart in both tone and volume with the Macan being very tolerable and in no way a nuisance. Thanks!
          I have done,
          -new shims
          -coated all metal on metal pad to caliper surfaces with anti squeal coating
          -moved from stock brembo pads to akebono ceramic pads (which claim zero noise)
          I need an answer here too, I'm using DS2500 and they are INSANELY loud and horrible. I don't know if I'm missing some magic trick here to get them to even shut up a little bit.
            I’m almost ready to go back to stock. This mod makes me hate to drive this car.
              I had squeaking issues too but I removed the shims and added break lube to the back of the break pads where the pistons make contact and the squeaking stopped. Hope this helps.
                Okay….. I did the following;
                -removed pads
                -removed shims
                -applied anti- squeal lube to the back of the pads, allowing it to dry for 48 hours
                -applied BG anti-squeal to the pads
                Then I gave it a good test drive and as soon as the brakes got hot, Squeal city.
                Does anyone know if this can be caused by a problem in the calipers? Pistons etc. I have never seen or had brakes make this much noise (excluding race pads).
                  I know it sounds crazy, but check to see if the edge of your rotors are rubbing on the calipers when they get hot … check the calipers to see if any paint has rubbed off. You might need to add spacers to the brackets to get some additional clearance.
                    -removed pads
                    -removed shims
                    Any reason to not try OE Textar or ATE pads? Yeah I get it they have more brake dust but historically they have no squeal issues.
                      I tried both stock Brembos and Akebono Brake Pads. Same result.
                        I checked. It close but has not touched.
                          Stock Brembo and Akebono are neither ATE nor Textar. So I ask again, why not use OE Porsche pads?
                            Do you happen to know the part number for those pads? Thanks
                              If you are using CSL rotors front and rear the use TEX-2193702 and TEX-2332902 pads for front and rear. Both available on FCP Euro.
                                Thanks, I will give the textar pads a shot. Third time is a charm……
