Originally posted by RazorM
E86 Front Triangulation Braces Retrofit
I actually asked my coworkers boyfriend about this, who's a lead chassis designer at a world-renown automotive manufacturer. Wish I still had his big blurb, but basically, the gain by merely tying it in is so substantial, that as long as your tube stiffness is reasonable, the gains switching materials is so marginal it wouldn't be recognizable. He then said I could do it in chromium, but we didn't talk about temperature. There is tension fatigue, but the bar itself is so cheap it hardly comes into consideration.
- Likes 3
Hell yeah! I'm excited to see the design you come up with.Originally posted by bigjae46 View PostStill have some finishing work to do. Now on to figuring out the strut mounts and mounting the bars. The challenge here is serviceability. I would like the two new braces to mount under the OEM bar so it is less to remove if I need to remove the intake manifold.
I am also going to do the strut tower mounts in long strand forged carbon. I am leaning towards making them thinner like Heinz’s process to fit the 3rd lug so I can make a plate which goes between the cross bar and the strut plates. Then bolt the triangle braces to the plate…like Heinz’s design.
Or maybe I mount the two braces under the strut tower plate and run a bolt through…
Yeah, like you said, I went this route mostly for crash safety.Originally posted by RazorM View PostAmazing project and effort! Can’t fully say how much I appreciate this. Hopefully more people will get to use this diy for their cars and change the car for better.
I have a question. What is the reason to use or start with OEM aluminum strut brace? Are not there better and way stiffer 3piece alternatives like DMG or so? Since you can also remove the middle section of the brace for easier serviceability.
I understand that in an event of crash stiffer braces may damage the car more. But was it so big priority or you think there is not much of a stiffness available to be gained?
Designs like the DMG bar are useful because they help reduce strut tower fore/aft deflection (relative to the other strut tower) with the torsionally stiffer bar. However, tying the strut towers directly into the firewall (which is essentially immovable in comparison) constrains the fore/aft deflection, so I don't think there's much to be gained from a stiffer middle bar.
Also, both the E46 and E86 braces are notched and designed to fail before anything else in a crash. Since they don't fail during normal use, there is likely little to be gained by upping the stiffness of each individual part.
Glad to hear that coming from someone with the appropriate credentials!Originally posted by YoitsTmac View PostI actually asked my coworkers boyfriend about this, who's a lead chassis designer at a world-renown automotive manufacturer. Wish I still had his big blurb, but basically, the gain by merely tying it in is so substantial, that as long as your tube stiffness is reasonable, the gains switching materials is so marginal it wouldn't be recognizable. He then said I could do it in chromium, but we didn't talk about temperature. There is tension fatigue, but the bar itself is so cheap it hardly comes into consideration.
Also, temp data coming soon:
- Likes 5
Some updates on the remaining bits of this project in my journal, in case anyone wants to follow along with the development: https://nam3forum.com/forums/forum/m...477#post324477
Track day coming up, so should have some solid temp data next week for you guys. Preliminary data is promising.
Also, printing up the first full scale prototype of the modified cabin air filter housing as we speak. Hoping that the design for that doesn't need too many iterations.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
- Likes 4
Track day thermocouple results are in!
The max temp the windshield mount saw was 65.5 C, but at steady state, it hovers right around 40 C.
This means that the part will see essentially no temp degradation at that location. Rest assured that the 7075-T6 version will not spontaneously fail on you
For anyone curious, here's a more detailed analysis of the data: https://nam3forum.com/forums/forum/m...636#post3276362002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
- Likes 4
If there's a list for parts order for this project to bring the cost down per piece, let me know please.2006 Silber Grau Metalizat ZCP 6 MT
25mmOriginally posted by bigjae46 View PostDoes anyone have the outer diameter of the E86 braces?2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Lol all good.Originally posted by bigjae46 View Post
Fack! I store my car at the track, 40 min away and I forgot to measure how long.
Could you hook a brother up with the length too? Damn I'm a pain in the ass! 🤣🤣🤣
My design puts the brace mounting studs 555 +- 10 mm apart.
I don't really know how long a stock E86 brace is, as the ones on my car have been shortened a but. Guessing stock is closer to 600 mm.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
This looks awesome, an alternative to the Slon brace that I so wanted (I love chassis rigidity) but could never justify spending that much money on. But it does seem a little intimidating for a guy who has never worked with a machine shop or welded (I do great at bolting on stuff🙂).
EDIT: In reference to my question above, I went back into the Google doc in detail.
Again I would like to recognize Heinzboehmer for his amazing ingenuity, dedication, and attention to detail of this design. It is truly high watering for an enthusiast to do this themselves. And the fact that this has been provided all open source, free of charge, is a testament to him, this website and the community in whole.
However, with the amount of 3-D printing, CNC machining, and other welding/fabrication currently involved i’m not confident in my ability to do this. I will cheer you all on from the sidelines and wait until either this develops into a full purchasable kit (if Heinzboehmer or someone else so chooses) or bite the bullet for the Slon brace. This makes the Slon brace look not as overpriced as I thought before. If it weren’t for that damn cabin air filter housing…Last edited by Maxhouse97; 12-21-2025, 03:51 AM.‘04 M3
It's done!
Well, sorta. Still need to do some finishing work (sanding, painting, etc.) to make it truly invisible in the engine bay, but all design work is complete.
I'll try to spend some time this week bringing the documentation up to speed. Will update here when that's finished.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
- Likes 9
Looks so OEM an clean! Great work.Originally posted by heinzboehmer View PostIt's done!
Epic! Not many DIY projects incorporate an actual performance improvement and maintains all OE functions, serviceability and aesthetics. Remarkable!Originally posted by heinzboehmer View PostIt's done!
Originally posted by 0-60motorsports View PostLooks so OEM an clean! Great work.Thanks!Originally posted by bigjae46 View PostEpic! Not many DIY projects incorporate an actual performance improvement and maintains all OE functions, serviceability and aesthetics. Remarkable!
Did my best to retain all OE functions, but I'd be lying if I said there wasn't some compromise. Fortunately, the compromise is almost entirely related to the install of the modified HVAC plastic parts.
There's just more stuff crammed back there (braces and all the gaskets needed to seal around them), so it takes a bit more wiggling to get it to seat nicely. The access for the middle fastener on the cabin air filter housing is also tight, but it does work just fine.
Everything else is very much stock-like
- Likes 4
Working on the strut tower plate compression mold. I added a tab for the firewall tubes. Just needs a little more prep, install the barrier fences, release, and then pour the casting resin. I will use long strand carbon for better strength and stiffness properties. I may add additional steel reinforcement underneath where the bars bolt to.
This should be cheaper to make but may require a different brace bar. And the tab may not be on the same plane as the firewall mount so the tubing may need a bend.
- Likes 4
