Thanks PHX, would doing f80 front and rear be too rear biased for mk60?
F8X Brembo BBK Swap on E46 M3
Originally posted by enjoy_m3 View PostThanks PHX, would doing f80 front and rear be too rear biased for mk60?
Hey Johnvu, I wanted to thank you for your very detailed very precise orientation on how to do this conversion. I was able to follow your step by step and install mines. And btw, for all those out there wondering if you can fit this on 18 wheels…yes it is possible, here are some pics.4 Photos
For those thinking F80 fronts are a little too big, FreakyParts over in the UK sells a front kit that puts a Renault Megane Brembo caliper (same as the buildjournal) on a e90 front rotor. It’s 360 x 30. So 15mm larger diameter and 2mm thicker than ZCP. I installed this on my car last month and am very happy so far, will try it out on the track this spring. I have the 996 setup on the rear.‘04 M3
- Likes 2
Originally posted by D10GO View PostHey Johnvu, I wanted to thank you for your very detailed very precise orientation on how to do this conversion. I was able to follow your step by step and install mines. And btw, for all those out there wondering if you can fit this on 18 wheels…yes it is possible, here are some pics.
Originally posted by ra2fanatic View PostWaiting for someone to install CCB's onto their E46 M3 from the F8x platform. Makes no sense because you'll be able to only run a select set of 19s, but damn that would look good.
Originally posted by phoenx View Post
Funny enough, the ceramics on my f80 will be coming off in the summer and it wouldnt be a bad idea to throw them on my e46! Only thing that would hold me back are having to use very specific set of 19's because not all 19's clear these brakes.It would be dope though. Do it!
Originally posted by YoitsTmac View PostBump. Final plea for a brake line vendor? It’s the last piece I need
Edit: this is for the front
