380 is too large to be beneficial for sure. Can’t run 18s, which are way better for this car on track than 19s, much less 17s. No need for the extra heat capacity over 355s.
Apex lists several 380mm kits that fit under their 18" wheels, and 18" wheels fit over the F8X brakes on the F8X cars... between those two pieces of information, I don't think it's a reach to assume there are readily available 18s you can run.
Yeah, apex goes out of the way to make it work. My track setup is 17” apex wheels, which are the only 17s I know of that can clear 355mm BBKs... which I meant I had to compromise other things to run 17s. With 380s you’re making the same compromises in order to run 18s, with no hope of 17s.
... not to mention that the 380s are extra unsprung mass and rotational inertia without a functional benefit over 355s.
Both set ups have their own positives. If you are going for ultimate light wight in which 20 lbs is going to make a difference, then yeah it seems like the 996 swap is the way to go. However, most people won't be anywhere near that level of weight reduction.
In my opinion, the f8x swap is the most cost effective system that substantially upgrades the brakes over oem. However, I honestly dont think you can really go wrong with either of the swaps bc both are way better than factory.
ARC8 is the only Apex wheel that wouldn't fit (barrel wise). All others will fit on an M3/4, including the newer Forged Arc8R.
I had to sell my Arc8 track setup when I moved to f8x brakes on my e92m3.
These are BW TA5R in the common track 18x10 et25 size (after a track day)
Any info on the brake bias? I have the E31/996 combo laying around and would like to know if this is a better solution?
I don't have exact numbers but from what I have read on M3Cutters and another member on page 3, it looks like brake bias is slightly rear biased on the 2001-2003.5 models, and near perfect for the 2003.5+ models we the updated ABS system. I am running some Ferodo DS2500 pads and all around daily and plan to switch the fronts to DS1.11 for track days. I have heard this works well and it should also help with the rear bias.
So if i need to source the set, what donor car and year im looking for? I check realoem and partnumber and found these cars with the same caliper/rotors, is the list correct?
thanks all, really not familiar with newer cars and since ill be needing pads and rotors soon on my zcp perhaps add more money and upgrade to this setup.
All the M cars on that list will have them, but the non-M cars would have to have been optioned to have the same brakes as the M cars. M2 Competition have different brakes -- they came after the M2 LCI cars.
are there any markings on calipers or as long as they blue like the first post and just avoid the m2 competition?
This came off of other cars like the M235i, I want to say they mate with different brackets for different sized rotors? But I'm not 100% on the difference. So blue alone isn't correct.
If they're blue and came off of one of the cars that you listed first (and/or part number matches) then you're good.
