OE manufacturer part list
    Originally posted by 8000RPM View Post
    Well known but here are the pics. Lemfoerder FCAB and Lower control arms
    I remember doing this job and comparing the parts like you. Then I saw it was missing the
    ///M engraving and cried a little inside.
      Is there an OE equivalent for the BMW ignition coil? Eldor or Bosch? I thought I remember there being a country of manufacturer change.
        Valve seals. BMW brand on the right. Corteco on the left.
        I have the elring right next to me as well. BMW brand is different than all of them.
          ^ Thanks for the posting that. It looks like OE is the way to go for the seals.
            What is the consensus on the OE/OEM water pump? I’m concerned mainly about the impeller being metal, but of course the bearings as well.
            I am ready to replace the water pump as a preventative measure. Would love to save the money if possible, but don’t want to install a lesser capable pump - if that’s the case.
              Just buy the genuine one. You can't get the OE part directly from the manufacturer.
              I know this is only one data point, but I had a metal impeller one on my car (Geba I think) and it started leaking coolant through the bearing/shaft after only about 15k mi. Replaced it with the genuine BMW part and all has been good.
                Agreed, just go with the proven Genuine BMW Part on this. It lasts a long time and prob last one you’ll need.
                  Anyone have any experience with the high pressure power steering hose?
                  FCP says Rein is OE, so I ordered that when I did a power steering refresh about a year ago. However, hose started weeping pretty bad after a recent track day. Comparing pictures, the BMW part looks different to the Rein part (crimp fittings are silver vs black), but that might just be outdated pictures.
                  I'll probably just order the genuine part this time, but wanted to see if anyone had compared them side by side.
                    OE was Continental, probably before being bought by CRP (Rein)?
                    A bought a new Rein, but was dismayed by the speed at which they'd start leaking again, per reviews on m3f, so I installed a low mileage factory one instead.
                      Good to know I'm not the only one that had issues with the Rein part. Genuine part ordered, will update this thread with differences (if any) once I have both of them in hand.
                        I couldn't get the E36 hoses to be reliable in my track car, so I just gave up and went full braided lines + AN fittings with an inline cooler and oversized reservoir.
                          Crap. I just ordered the Rein one. My current high pressure hose (Genuine) has about 45k miles and is fine, but with everything torn apart, it's a "might as well" part. Maybe I return it and go OE?
                          I have a lot of might as well parts being thrown at this car. My current dilemma/decisions are the starter (it's fine but...), the aux cooling fan (they are $$$) and aux water pump.
                            I would just keep using your original.
                              I’ve heard people complain that custom lines with AN fitting cause steering whine. Are you experiencing that?
                              2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 288/280 Schrick Cams+DLC Followers | Lang Head | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 400/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | Turbo Toys V2 Hub | WPC Rod Bearings
                                Nope, but I'll keep an ear out.
