Review: Cobra Nogaro seats (uniquely street friendly fixed back bucket seat)
    The Nogaro is ~429mm wide at the mount points, IIRC
      Got a reply back from Cobra. They state that it's 405mm between the width of the mounting points and 290mm between the 2 side mounting holes.
      That put it exactly like the Recaro Pole.
      Obioban are you certain about the 430mm width mouthing points?
      Thanks
        If you heard from Cobra, I'd trust that.
          Thanks
          Not certain at all! Was going off a vague recollection from measuring them back when I first installed them years ago.
            Thanks guys..
            Here is another option for brackets based on cobras dimensions.
            This company is well respected in the racing community here and it's cheaper as well. You don't have to pay extra for sliders handle.
            They also provide material report which is required for TÜV.
            ​​​https://www.speedengineering.de/prod...r-komplettset/
              Thanks guys..
              Here is another option for brackets based on dimensions.
              The company is well respected in the racing community here and it's cheaper as well. You don't have to pay extra for sliders handle.
              Interesting option. Presumably they make this only for the manual BMW OEM sliders? I didn't see an option for the power seat rails.
              It also looks like they have a complete custom in-house mounting solution that doesn't use the BMW sliders at all:
              https://www.speedengineering.de/prod...pole-position/
              If I'm interpreting this right, it also looks like they have seat belt mounts for the passenger and driver side that allow the factory seat belt receiver (the one mounted to the OEM BMW rails) to be used:
              Driver side
              Passenger side
                Thanks guys..
                Looks like those are pole position specific.
                  It also looks like they have a complete customer in-house mounting solution that doesn't use the BMW sliders at all:
                  Driver side
                  Passenger side
                  I don't think manual or electric will need a specific bracket as the mounting 4 bolts are the same between the two.
                  I'm only interested in using the original seat base. There plenty other companies that offer seat mounting solutions for the e46 chassis.
                  ​​​​​As for the seat belt mounting, if the stock based it's used, then the seat belt retractor will just bolt up to the base/stock mount.
                    Yes they are pole position spec, but from what I've gathered from the mounting points, it should bolt up to the cobras as the mounting dimensions are the same.
                      Thanks guys..
                      That looks so much better than the BK brackets. I do not rate the BK brackets highly after owning them. I might end up ordering a set of these and see how they compare.
                        Got it. I just went back to check the BK mounts and for some reason I thought they had two versions, power vs. manual slider mounts. I remembered incorrectly!
                        The one thing about the Cobras vs. the Recaros. The mounts on the Speed Engineering pieces seem like they might come up higher on the sides of the seat (the outside edge where the mounts bolt up to the seat) than on the BKs. Given how low-slung the Cobra seats are in the leg bolster area, I wonder if these mounts will interfere with the seat in any area. I've run into this issue with generic, non-seat specific mounts in other race buckets and it makes the installation a bit of a pain. Heck, my OMP seat with OMP seat brackets interfered with each other...
                        Horrible mock-ups below, but I see 2 potential problem areas. The vertical rise area circled in red below (blue is the rear, shouldn't be an issue):
                        Click image for larger version  Name:	Speed Engineering mounts.jpg Views:	0 Size:	58.0 KB ID:	194934
                        In this pic, the hole-to-hole dimensions might be longer than on the BK mounts (pictures just below the first pic). This is where I've run into interference issues with seats in the past.
                        Also, I wonder how high these mounts will push the seat up (the arrow in the left hand side below)? Without laying the BK mounts and the Speed Engineering mounts side-by-side, it's really hard to tell.
                        Click image for larger version  Name:	Speed Engineering mounts 2.jpg Views:	0 Size:	60.0 KB ID:	194933
                        BK's for reference:
                        Click image for larger version  Name:	BK Nogaro mounts 1.jpg Views:	0 Size:	62.8 KB ID:	194935
                        And Ian's seat. Not sure how much room is above the forward mounting hole and if these Speed Engineering mounts will interfere or not.
                          The one in that picture didn’t end up being the final mount design. See how it’s bolted to the top of the slider in the rear, instead of on the side, like the final version.
                            How high up does the mount protrude along the seat edge on the production version? This is the bit (blue line) I'm most concerned about:
                              You have raised some great points. I've sent out an email to speed engineering and pointed them to this thread. Let see if we can get some answers.
                                Don't know, sadly.
