List Your Suspension/Wheels/Tires Setup in Great Detail
    Originally posted by BMWahba View Post
    This thread would benefit with accompanying each post with photos too
    Right? 😂
      Originally posted by DiscoWagon View Post
      How/Where I Drive: 80% Track 20% Street
      Öhlins Dedicated Track Coilover Kit
      Corner Balance and Alignment by Chewerks
      Front:
      Apex ARC-8 18x9.5 et22
      Bridgestone Potenza RE-71R 265/35/35
      Camber: -3.7 degrees
      Rubs: No
      Spacers: None
      Springs: Swift - Öhlins Spec 700#
      Camber Plates: Öhlins w/ spherical bushings
      Ride Height: 13.5 inches (from center of wheel to quarter panel arch)
      End Links: Turner Motorsport adjustable
      Control Arm: OEM
      Sway Bar: OEM
      Tie Rods: OEM
      FCAB: Bimmerworld Race
      Brakes: OEM ZCP w/ Endless ME20 race pads, Endless RF650 fluid
      Rear:
      Camber: -2.7 degrees
      Rubs: No
      Spacers: None
      Springs: Swift - Öhlins Spec 900#
      RSM: Öhlins w/ spherical bushings
      Ride Height: 13 inches (from center of wheel to quarter panel arch)
      End Links: OEM
      Ball Joints: OEM
      Bushings (except RTAB): Powerflex Black
      Sway Bar: OEM
      ARCAs: Bimmerworld
      RTABS: Powerflex Black
      Regarding the fronts, is this -3.7 kind of the standard to fit a 18x9.5 ET22 on the front? or can you get away with any less? I have a set of wheels in this same square size with 255/40/18 RT615Ks and KW Clubsports I'm planning on putting on my car... someday before I die.
        50% Track 50% Canyons
        No, it doesn't rub, lol.
        Moton Motorsport 3-way + rear coilover
        Front:
        BBS RIA 18x10.5+22
        BFG Rival S 1.5 275/35-18
        Springs: Swift - 12kg/700#
        Ride Height: 13.0" (from center of wheel to quarter panel arch)
        Sway Bar: Hotchkiss 30mm bar full stiff
        Rear:
        BBS RIA 18x10.5+22
        Camber: -2.5 degrees
        Springs: Swift - 9kg/500# (rear coilover, 2x OE motion ratio)
        Ride Height: 12.5" (from center of wheel to quarter panel arch)
        Sway Bar: None
          Ok I’ll play
          Front
          VMR 710 19x8.5 et35 (gunmetal)
          Firestone firehawk 500 255/35/19
          dinan strut bar
          hotchkis sway bars (middle setting)
          koni shocks (softest setting)
          eibach springs
          135i 6pot calipers
          ecs tuning 2 piece comp. rotors
          Rear
          VMR 710 19x9.5 et22
          firehawk 500 285/30/19
          dinan rear strut bar
          hotchkis sway bar (softest setting)
          koni (soft)
          eibach springs
          Porsche 996 4pot calipers
          oe comp. 2 piece rotorsClick image for larger version  Name:	8CD2C97C-2479-4B6D-BDD6-D4DF6F8D4D26.jpeg Views:	0 Size:	286.5 KB ID:	46630
            Oh there is plenty of clearance less, camber wouldn't cause any fitment issues; the settings are to optimize handling on the track. These are the specs that my alignment shop Chewerks recommended (he's very experienced in E46 M3 track setup).
            Current: 2003.5 E46 ///M3 6MT - 2019 Ford Raptor 802A
            Past: 2015 F80 ///M3 6MT - 2006 E46 ///M3 6MT - 1999 E36 ///M3 5MT - 1991 E30 ///M3 5MT
              Gotcha. Yea Robert aligned my E36 not long ago, I'm pretty new to the E46 platform so I'm trying to figure out where's a decent middle ground since -3.7 might be a *bit* much for around town. But maybe not. Who am I to question a tried and true setup after all?
              Fenders need to be rolled, or...?
                I'd assume it will depend on the ride height and spring rate you are running. Lower height will require stiffer spring with shorter bump travel so you dont take out your fenders/liners. Higher ride height can get away with less camber or softer spring.
                On camber, also depends on many variables. Tires with softer sidewalls will prob need a bit more camber, but for a super stiff car (springs/bars) without much body roll and stiff tire sidewall you would need less camber, and need to base it off your contact patch/temp gradient. I'd say 3.7 degrees is very aggressive and might be more of a autox setup, but again, depends on the test of the setup you run.
                Youtube DIYs and more
                  X2...A photo is a must with this info.
                  Evolve Eventuri
                    I added a pic to the original post and a request for people to add their pics.
ID:	88587 Click image for larger version
ID:	88588 Click image for larger version
ID:	88586 I wonder why this thread isn’t fully populated. Could have lots of good information in it.
                      How/Where I Drive: spirited driving on the streets/ 4-6 track events per year
                      How long have you ran this setup:
                      2-3 years now. Got 8 track days on my last set of tires and currently have 40,000 miles on my road setup tires.
                      KW V2 coilovers
                      Front:
                      Road: Style 68 18x9 et 26
                      Track: Apex ARC-8 19x9.5 et 35
                      Road: Continental Extreme Contact DWS 255/40/18
                      Track: Federal RS-RR 255/35/18
                      Camber Road: 2.0 degrees
                      Camber Track: 3.0-4.0 depending on track
                      Rubs: No
                      Spacers: None
                      Springs: varies based on ride height
                      Camber Plates: Vorshlag
                      Ride Height Road: 14 inches (from center of wheel to fender arch)
                      Ride Height Track: 13.5 inches
                      End Links: Ground Control
                      Control Arm: OE
                      Sway Bar: Ground Control
                      Tie Rods: OE
                      FCAB: OE
                      Brakes: OE, upgraded bushings, pads and have ducting
                      Rear:
                      Road:
                      Style 68 18x9 et 26
                      Camber Road: 1.0 degrees
                      Camber Track: 1.3 degrees
                      Rubs: No
                      Spacers: None
                      Ride Height Road: 13.5 inches (from center of wheel to fender arch)
                      Ride Height Track: 13 inches
                      End Links: OE
                      Ball Joints: OE
                      Bushings (except RTAB): OE
                      Sway Bar: OE
                      ARCAs: OE (reinforced)
                      RTABS: Syncro Design Works
                      Subframe: CMP Solid bushings
                      Subframe reinforcement: Full CMP kit
                      Brakes: OE, upgraded pads and bushings
                        Anyone know if 18x9.5 et22 square can fit with ohlins r&t and stock ohlins springs? Already bought my wheels so I'm committed, but a bit concerned about strut clearance.
                        Have yet to buy tyres as well so there could be some wiggle room there.
                          Those fit just fine. It's the ET35 wheel that has the spring perch clearance issue.
                            Good to hear, cheers.
                              Notes: Car is stupid flat in the corners and absolute Nirvana on track (epic track bros: take a seat, this is relative to my humble vehicular experiences). Driving on bumpy midwest roads is tolerable sometimes and makes me want to sell the car at other times. I will be running much softer spring rates in the next week or two since I value getting out and enjoying the car as much as possible and a softer ride should help with that. If I lived in a place with excellent roads I might only change the rear dampers to a Koni DA as I feel the SAs are slightly underdamped.
                              How/Where I Drive: Commute like an a-hole, 1 track day/year
                              How long have you ran this setup: 3 years, 12,000 miles, 5 track days between myself and the PO
                              Ground Control Coilovers (Koni SA/Eibach)
                              Front:
                              Apex ARC-8 18x9.5 ET22 Hyper Black
                              Hankook RS-4 265/35-18
                              Camber: 3.1 degrees
                              Rubs: Very minimal on fender plastics when there is a lot of steering angle. Eventually it will work itself out.
                              Spacers: None
                              Springs: 6" 525 lb/in Eibach. I will soon be changing to 375 lb/in because I believe I will enjoy commuting more on these horrendous midwest roads.
                              Camber Plates: Ground Control
                              Ride Height: 13.75 inches (from center of wheel to fender arch)
                              End Links: Ground Control adjustable
                              Control Arm: OE
                              Sway Bar: Ground Control adjustable
                              Tie Rods: OE
                              FCAB: Bimmerworld TrackCAB
                              Brakes: PFC Direct Drive rotors, PFC Z-rated pads (street) PFC 08 pads (track)
                              Rear:
                              Camber: 2.4 degrees
                              Rubs: No
                              Spacers: None
                              Springs: 7" 650 lb/in Eibach (switching to 430 lb/in)
                              Ride Height: 13.38 inches (from center of wheel to quarter panel arch)
                              Ball Joints: OE
                              Bushings (except RTAB): Bimmerworld Spherical
                              ARCAs: Ground Control Monoball
                              RTABS: Bimmerworld
                              Subframe: Bimmerworld Solid alum.
                              Brakes: PFC Z-rated (street) PFC 332 pads (track)
                              Click image for larger version  Name:	16FE2B3C-FADA-47DD-9332-796D5455EE1C.jpeg Views:	0 Size:	131.6 KB ID:	97131 Click image for larger version  Name:	7AC53739-C673-4C1D-8F13-952412AE6770.jpeg Views:	0 Size:	194.0 KB ID:	97130
                                Street/Cyn
                                Front:
                                OE CSL 19" x 8.5 et44
                                I'm beyond jealous of your CSL fronts
