This is a sticky topic.
    Originally posted by Fitzy View Post
    I’ll keep that in mind thanks 😂 hey I see you’re in Minneapolis too, maybe I’ll see you cruising around!
    I'm in Minnetonka. Seen a few black E46 M3s around this side of town. If you get those headers & Sunbeam installed, I'll know it's you!
      I never looked at my fuel pump before, but was curious.
      I'm going to guess based on the dirt it's original. Cleaned it up a bit more and it's a VDO with a blue top. Original most likely?
      Also, if so, wait to get stranded or proactive replacement? Car is an 04 with 71k on it. I know there are a probably a billion threads on fuel pumps here that I can read based on the answer of replace or not.
      Thanks.
Name:	Screenshot 2026-05-30 3.46.53 PM.png
        I have a fuel pump relay code, I can clear the code, run the fuel pump test via INPA and the code comes back everytime.
        The vehicle is not showing any symptoms whatsoever of a bad fuel pump, it's fires everytime immediately, no hesitation. I have not tested fuel pressure.
        I have read that it's possible a failing pump can draw more current on startup causing this code to appear.
        I am thinking of trying a cheap used relay as new ones are $150. The prongs on the relay look fine, no signs of excessive heat etc.
        What all should I be looking at/testing?
          The top connector for vacuum became separated from my Karbonius intake. Is there a recommended glue? Do I need to sand it?
            Some new error codes yesterday. I hardly use the AC (drive with the windows down), but yesterday was especially hot and when I took one of the cars to pick up the kids from school in 95* temperatures, I tried to turn the AC on. Snowflake would illuminate and turn off immediately, and the air speed would be limited to 50%. Ambient air temperature reached 110*.
            Plugged in the laptop and got these two codes:
            24 Additional heater relay
            Error frequency: 10
            short circuit to batt+
            Errorcode: 18010A2445C088510386
            255 Energy saving mode active
            Error frequency: 1
            short circuit to ground
            error present
            Errorcode: FF42012489CF88510375
            Anyone with a similar experience?
            David
            Bumping this up - haven't addressed this in weeks since I haven't driven the car much. Any ideas?
              Thanks.
              I would buy a fuel pump now if you're really motivated and keep on the shelf when you need it... probably a ton of life left in your pump.
              David
                Thanks.
                That is an original pump as you can tell by the glue they put on the ring and pump from factory. 71k is nothing for these fuel pumps. They can go 100k plus if one is using good fuel, refilling on a regular basis and not constantly driving around with the tank on empty.
                  JB Weld Plastic Bonder 50139 works well for a CF/metal bond and is low cost.
                  Loctite 9460 Hysol Non Sag Epoxy Structural Adhesive is more professional stuff.
                    Thank you. I had the 9640 in my cart. Any reason I wouldn't use that beyond that you need a special gun to properly use it?
                      So I replaced my door seals as well as the inner seal for the rear vent windows because they'd leak. Took it through a touchless wash and the window behind me leaked just as bad before. I'm assuming it's the window actuator motor now. They look to be back ordered on Turner, FCP, ECS, etc. with no ETA. Anyone know where to score a new one of these?
                        I'd probably be grabbing some from a junkyard or ebay at this point as they may not be comming back.
                        Too bad they aren't interchangeable as even used stuff isn't cheap when considering the part.
                        You might also check that there isnt any significant play in the armature portion.
                          Was cleaning my eventuri intake. The gasket between the housing and the filter broke. No problem, I got a replacement from IND. Then, after trying to put it back together the rubber seal that goes around the filter snapped while trying to wedge it back into the carbon fiber housing.
                          Do you think that rubber seal is actually necessary, or is that gasket that sits between the housing and the filter good enough?
                          Also - never cleaning my filter again. What a pain.
                          Thanks.
                            Thanks.
                            There's almost no such thing as good enough when it comes to sealing your air intake downstream of the filter. You want an excellent seal between the filter and the housing, and an excellent seal at every step from there to the head. Don't compromise. If a sealing piece was there and now it's not, definitely find a way to put it back. Make sure everything's lined up right, too.
                            And yeah, filter cleaning is a scam. Annoying, yes – and unless you do it absolutely perfectly every time, which you won't because you're a human being and the real world isn't a lab, you'll end up with worse flow, worse filtration, or both.
                            2008 E90 M3 6MT
                            2011 E90 328i 6MT
                            RWD, slicktop, no iDrive
                              There’s some sort of object (perhaps a nut or screw) that’s been rattling back and forth above the headliner for the past couple weeks that’s been driving me nuts. I removed the sunroof motor cover and the center light console but couldn’t find anything which leads me to believe that something came loose when I opened the sunroof a few weeks ago. Anyone have any insight or remedy that doesn’t involve dropping the headliner?
                              2002 TiAg/M-Texture
                                To locate it bang around the headliner like when you drop a bolt in your engine bay and it lands on top of one of the splash guards.
                                Also you could use a decent resolution borescore camera to check things out.
                                If magnetic it could maybe be retrieved with a bendy magnet, if not maybe some wire.
