How difficult are RTD/CAE shifters to remove and replace with OEM?
    Quick question, might delete.
    I'm currently on the hunt for my M3 and I've come across two that appear to be good deals-- good prices with lots of maintenance and service records. The only problem is that one of them has a crazy looking CAE shifter and the other one has an RTD short shift kit. I just want a simple OEM style shifter (first manual car) and I'd like to not write both of these cars off just because of that when everything else seems to check out. Pics below.
    Thanks guys!
    2018 BMW ///M3
    Daytona Violet/Carbon Cloth ZCP + DCT
    Is this originally a manual car, or an SMG converted to manual?
      Thanks guys!
      The CAE shifter is chassis mounted and should be fairly easy to remove, but you may just like it enough to keep it. It's a bit like a fine bolt-action rifle when shifting with the CAE.
      Feff
      MVP Track Time
        This. It's possible that the car with the CAE shifter was originally SMG. That shifter has its own detents, which makes it so you don't have to machine the trans bell housing. If this is the case, then replacing the shifter with OEM would require that you also drop the trans, machine the bell housing and add the detent springs and related parts.
          The RTD car has an SMG cluster and the picture of the CAE looks to have a manual cluster. That leads me to believe you wouldn't be able to remove the RTD without pulling the transmission and finishing the SMG swap.
            Good eye. The RTD car would need a good amount of work to go to an OEM shifter. Also based on the link you posted in the craigslist thread MTiz , the CAE car is probably a factory manual since it's got a manual plenum. That one should be much easier to swap out.
              You’ll like the shifter so much you won’t want to go back to stock. I planned to remove my RTD shifter since I thought it looked odd in the car, but It was too fun to shift I couldn’t go back to stock. One of my favorite things is it removes the “slop” in the shifter. But it in 3rd gear and the shifter won’t wiggle even a 1/8 inch.
                First manual and you have the option to have a CAE from the get go? No brainer that has to stay. I don't understand the hesitancy for people to say it's overkill. Overkill if you have to maybe initially put the money down to buy one, but if's already there, the homework has been done to have the best shifter in the vehicle. Have at it and have fun.
                  This thread is a prime example of why I love this forum. Not only did everyone answer my questions quickly, you guys even clued me in that the Tiag car was a manual swap just from looking at the cluster (there was no mention of a swap on Marketplace and I definitely wouldn't have looked at the cluster).
                  If I do end up going with the CAE car who knows, I might end up loving it like a bunch of you guys mentioned. Thanks a lot!
                  2018 BMW ///M3
                    I had the RTD and currently have the CAE. CAE is the better choice.
                      How can you tell the difference?
                        Yes, CAE is better. I used to have both also, and CAE is better finish quality also.
                          Sorry, I meant regarding the gauge clusters
                            You can juuuuust barely make out that the gear position indicator is still present, although the lights are disabled. With the SMG swap and self-centering shifter it's a high possibility that the bellhousing has not been modified to accept the self-centering spring
                              Not debating you, but why would you recommend someone’s first manual car to be one with the CAE shifter?
