Red Oil Pressure Light comes on when idling (right after rod bearing replacement)
    I would suggest actually measuring oil pressure with a good old gauge before throwing any more money/parts at the car.
    Honestly, this should have been done before the 2nd rod bearing job.
      Damn, sucks that you had to pay for this twice and the issue hasn't gone away (hey, at least you got welcomed to the spendy part of m ownership). You mentioned a thorough inspection of the oil pump, but did you have the pickup tube o-ring replaced?
      If yes, then maybe this is a sensor issue? I would suggest actually measuring oil pressure with a good old gauge before throwing any more money/parts at the car.
      Yes, we actually replaced the pickup tube o-ring. I wasn't going to as I didn't think it was very important, but my indy strongly recommended it.
      Honestly, this should have been done before the 2nd-rod bearing job.
      A new oil pressure sensor was put on after the first job as a diagnosis and the issue didn't go away. As far as a manual oil pressure test, I literally asked them to do this but they immediately began blaming the extra clearance bearings as the culprit. I am 110% getting that done next.
        If you are paying the bill....
          What is Gennady's take on the issue?
            Just reached out to them and they said they ran a mechanical pressure gauge on the oil filter housing and everything was within spec before I took delivery a few days ago. I'm gonna do some more digging on the other forums as it doesn't look like anyone on here has had a similar issue.
              Very similar to yours. See post 9 for what the issue ultimately was.
                Ask them what was the measured pressure at operating temperature and idling. You should do it yourself.
                  I think I will. Any idea on a good tool kit for this?
                    It’s your oil pump. Had the same problem recently and it was a faulty pump. We also ran the test on the oil filter housing to test oil pressure. And surely enough it was slightly low.
                      buy or rent a gauge with hose set from Auto Zone or O’Riley
                        Since you had the shop replace the bearings a second time, I'm going to assume you think they are competent mechanics.
                        I would tell them the oil pressure light is still on. I would ask them to hook up the gauge with the car at operating temp and then you go an verify the readings. IF it's good you have a wiring issue. If it's not you should discuss options with them as they said they already checked it, this should be a mutual effort to resolve it now.
                          How do I hookup the mechanical pressure gauge without moving the airbox? The oil cooler lines are mostly in the way and I can barely stick my fingers in there.
                            Can you take the factory oil pressure idiot switch out and hook the gauge up to that port? I believe its on the oil filter housing. Might need to take the airbox out to get to it easily.
                            Or, some have had oil filter caps tapped with 1/8 npt. Though some claim the readings are skewed based on if the oil thermostat is open or closed.
                              That's exactly what I'm trying to do, I just wanted to know if there was a trick to getting to it without removing the airbox and the headache that comes with that.
                                Sorry mate, I think its a pita either way.
                                See page 10, there is a special tool for measuring at the oil filter cap:
