Yes, I should have clarified that it depends on the setup - is top perch above or below the point where you're removing stack?
So in your example, you'll gain a little bump travel (shaft travel) without affecting ride height. Or, they way I looked at it always wanteing to lower the car: maintain the same travel, but still get to lower the car for "free."
But replacing the stock mounts for thinner camber plates will lower the car rather than simply give you more travel because you've change the top spring perch's location relative to the strut housing. If you had adjustable coilovers, you could then scoot up the bottom perch or put in taller springs.
So pairing thinner camber plates, and not using a spacer like TMS', with stock style spring and strut, is something to do if you wish to get the car a little lower (good for B12 which is gas pressurized) without compromising travel.
. Shorter + stiffer sounds like if I do contact the bump stop, the crash will be much harsher. Think I'd rather keep the longer, less stiff, more progressive ones for that reason. But once again, I'm no suspension engineer so no idea if my intuition is correct or not.
