Black & Tan 332iT
    Careful, the PNs are different between sedan/coupe and wagon. Also don't forget the backing plate that goes in the trunk and sandwiches the rails as well, but that is something you could easily get waterjet and bent with sendcutsend
    Good call. For the record:
      Still planning on swapping in the M3 floor and exhaust? Don't know too much about these hitches, but will the wagon version still fit with that muffler on?
        Word on the street is that it should still fit. For now I’m going to keep the standard twin pipes. With the vincebar and v-brace installations looming, I’ve got plenty of work cut out for myself on the back end already.
          Spent a few minutes last night to design a solid/spherical bearing replacement for the steering guibo, another mill/lathe project once I free up the time
            I thought this was a 'no no' with LHD cars since the rubber guibo compensates for misalignment while RHD cars have a UJ. Solid steering couplers on LHD cars can damage or wear the steering rack IIRC. That's why places like CMP only sell a solid coupler for RHD. I'm sure there was a discussion about it a while ago but I could be misremembering.
              It’s hard to tell from the image but there are four spherical bearings, $12/ea in that design above. They provide the same amount of articulation as a factory setup good callout though, you’re absolutely right that a solid adapter is a no no
                Interesting in hearing your thoughts about that steering coupler. Especially considering how sensitive you are to NVH
                Maybe you could start with one of the off the shelf ones and drill it out to accommodate the spherical bearings. Would save you a bit of work. Most of them have reliefs cut out though, so not sure if you'd have enough material to work with.
                  I'm wondering if there has there been feedback that these solid couplings make any noticeable difference to steering feel. Cool idea and neat little machining project with the sphericals though
                    I had one on my car for a bit (didn't give it too much thought then, fortunately rack seems fine), but have since replaced with the regular rubber one. Did make the steering feel more direct, but also made it much more twitchy. Did not eliminate all of the on center deadness that the M3 racks have.
                      Pretty much agree with Heinz above. I run CMP's coupler since I am RHD. Deadspot in the centre is still there (I think that is just a function of the geometry and design of the steering on these cars tbh) but the feel through the steering is improved but it's not earth shattering.
                        Pretty much every BMW since the e46 is solid, even the e39 was solid in the same generation. NVH isn’t bad in those cars so I’m assuming it shouldn’t translate up the wheel. I’ll be sure to notice though, as Heinz says. And I’m not afraid to go back to stock if something sucks.
                        heinzboehmer (& Thoglan) less rear toe in really helps with the numb on center feel. Since you’ve got sphericals back there, you should run CSL specs or similar. Way different settings.
                          Slon just sent me these pics, I had the strut mounts anodized black to be a little more stealthy. Install coming soon!
                          Click image for larger version  Name:	6E42099B-95E2-44F9-ABE2-3FBEDAD211D7.jpg Views:	4 Size:	83.0 KB ID:	209083 Click image for larger version  Name:	E457D653-56C5-451F-8250-6F163D26B8F1.jpg Views:	4 Size:	79.9 KB ID:	209084
                            Aluminum BMW/Westfalia hitch showed up today - time to clean it up and adapt this to the US stealth hitches design we've got on the Macan
ID:	209977 Click image for larger version
ID:	209978 Click image for larger version
ID:	209979 Click image for larger version
ID:	209980 Click image for larger version
Name:	Screenshot 2023-03-16 at 9.30.19 PM.png
                              Spent a few hours today cleaning up the hitch and dropping the smaller parts in the ultrasonic, then started the rebuild process for the 712 steering rack that's been sitting for months. It's got a little etching, so I'll basically be crossing my fingers that it seals.
ID:	210215 Click image for larger version
ID:	210216 Click image for larger version
ID:	210217 Click image for larger version
                                That's great. Where did you get parts to rebuild the steering rack?
