Black & Tan 332iT
    Actual weights from the bathroom scale, without heat shields or ABS sensors, repeatable 3x:
    E46 total 14lb ‎ = 6.35 kg
    E60 total 13lb ‎ = 5.897 kg
    E60 aluminum knuckle 5.4lb = 2.5kg
    so in theory the superknuckle is .15kg heavier than the e60 setup and .3kg lighter than the e46 setup. So no appreciable weight benefit, but definitely a stiffness increase along with a much larger (and stiffer) wheel bearing that happens to bolt in.
    I’ve also decided that I’m going to reduce the steering ratio on the next iteration to match the non-m 13.7:1 steering ratio (vs the M3 14.5:1 with the same rack) that I find preferable. After adjusting for wheelbase differences, here are some baseline comparisons from other cars:
    911 ST converted to e46: 13.5:1
    911 GT3 converted to e46: 12.8:1
    E90 M3 converted to e46: 13.3:1
    Wife's Macan converted to e46: 13.9:1
    So 13.7:1 has some good company, I guess that’s why it feels so nice. The MK60 is easy to program with a write-in steering ratio, so I’ll have to knock that out along with this change as well to keep DSC in its happy place.
      Thanks to George Hill (whom I trust greatly with my CAD files) who's already printed one up! Got some good feedback on socket clearance that I'm going to have to incorporate into the keep out space. And he's got so many spare parts that he's probably going to beat me to my own test fit cases Click image for larger version
      I also forgot to mention I started conceptual designs on a bolt in brake shield. I'll be tweaking it to incorporate a ducting feature that matches my scoop a bit better, and replaces the plastic part that zip-ties to the strut:
Name:	Screenshot 2025-03-18 at 8.11.16 PM.png
        Some comparison shots against the factory steel parts that look pretty cool:
Name:	Screenshot 2025-03-19 at 9.42.30 PM.png
ID:	298451 Click image for larger version
Name:	Screenshot 2025-03-19 at 9.42.08 PM.png
ID:	298450 Click image for larger version
Name:	Screenshot 2025-03-19 at 9.42.16 PM.png
ID:	298449 Click image for larger version
Name:	Screenshot 2025-03-19 at 9.42.56 PM.png
        And some shots of the brake shield/duct hybrid in progress:
Name:	Screenshot 2025-03-19 at 11.15.46 PM.png
ID:	298452 Click image for larger version
Name:	Screenshot 2025-03-19 at 11.16.00 PM.png
          Would be cool if your brake duct supported brake cooling hoses.
            Easy enough to design replacement bolt on backing plates that would adapt to a traditional hose - the backing plate should be easily replaceable with the rotor removed, no hub removal required.
              Fresh off the printer, complete with a few tweaks from George's lessons learned. Dimensions are looking good, just needed to make the tapped hole a little deeper for the ABS sensor mount.
ID:	298584 Click image for larger version
ID:	298581 Click image for larger version
ID:	298587 Click image for larger version
ID:	298585 Click image for larger version
ID:	298582 Click image for larger version
ID:	298588 Click image for larger version
ID:	298586 Click image for larger version
ID:	298590 Click image for larger version
ID:	298583 Click image for larger version
                Analysis run with the appropriate boundary conditions at the tie rods and strut tube. Interestingly it wasn't possible to use these during generative design. Looks more accurate now, this thing should be extremely beefy. Low stress and low displacement.
                Next up I will put the loads into the strut tube, tie rods and hub to see what that does to the simulation, instead of applying the loads directly to the part surfaces. The simulation can then factor in displacements of the steel parts as well as the aluminum parts.
Name:	Screenshot 2025-03-21 at 10.20.22 AM.png
ID:	298622 Click image for larger version
Name:	Screenshot 2025-03-21 at 10.21.10 AM.png
ID:	298621 Click image for larger version
Name:	Screenshot 2025-03-21 at 10.21.20 AM.png
ID:	298619 Click image for larger version
Name:	Screenshot 2025-03-21 at 10.21.28 AM.png
                  Hi Bryson... as for load cases I can think off...
                  * Pot hole, tough to estimate. I can ask around here to see if there is any directional input, like shock g's and damper speed.
                  * hitting a curb, although the week link here is the tie rod.
                  since we have more unknowns than not, one idea is to scan the OE design, and run the same modes, then you can have two data points you can use to compare under the same conditions.
                    Yeah, good idea. I was waiting for you to pop in here. thank you.
                    I’ve got the scan of the OE parts, just need to close the holes and make it a solid body.
                    I’ve also done a quick model of the tapered joints on the control arm and tie rod and placed the appropriate loads that put the tapers in bending. At first blush it looks like the control arm taper will fail before the knuckle by a small amount. I’ll need to disassemble a control arm to get good dimensions of the taper to make sure, I just estimated length of the taper based on an old iPhone scan.
                      Alright, so a couple people were skeptical that the e60 hubs would be compatible with the e46 DSC, enough so that it was starting to make me nervous. So let's address that in two ways:
                      First, let's break out the oscilloscope and check the output signals directly. These sensors are pretty clever, they are *active* and not passive like MK20. They output a square wave with a very short pull down from 12V to ~6V when they detect a trigger on the hub (this is very different from the e9x and e60 M5 still).
                      Here's what the e46/e6x non-M looks like on the active 2-wire system when spinning.
                      Ok, so we're looking good so far, let's make 100% sure we're right here by plugging the e60 sensor into the e46(it has the exact same keying on the connector) and firing up INPA to read the individual wheel speeds.
                      And would you look at that, it reads the sensor just perfectly
                        Also while we're on the subject of setting things right for the record, my 1:10 tapered reamer showed up. After fitting it into the stock e46 M3 tie rod and control arm balljoint locations, I can confirm without a doubt that the BMW taper is a 1:10 Diameter:Length, rather than a 1:8 or a 7 degree, cited elsewhere on the internet. This means that for every ten millimeters of length in the taper, the diameter grows 1mm. Yes, diameter, not radius. Always measure yourself folks!!
                        Also, based on the torques BMW is calling out for the control arm and tie rod M14 and M12 nuts, respectively, this is likely around a steel equivalent to a Grade 5.8 fastener. Plugging these numbers into the simulation yields the following results - the tie rod and knuckle will fail about the same time:
                        Click image for larger version  Name:	Screenshot 2025-03-22 at 6.21.28 PM.png Views:	0 Size:	637.1 KB ID:	298747 Click image for larger version  Name:	Screenshot 2025-03-22 at 6.21.50 PM.png Views:	0 Size:	645.4 KB ID:	298745 Click image for larger version  Name:	Screenshot 2025-03-22 at 6.22.20 PM.png Views:	0 Size:	709.7 KB ID:	298746
                        All this had me thinking some more. Once I get a control arm here to measure, I can press out the outer ball joint, and if it happens to be a common diameter (perhaps the same as the rears) then I can press in a bushing designed for double-shear. And instead of doing the factory taper joint, I can design this thing for a much stronger and stiffer double shear joint at the control arm. Porsche did this for the 991.2+ generation GT 911 and I always thought this was a really clever way to stiffen the knuckle up and provide better wheel control, see below:
                        Click image for larger version  Name:	991-porsche-gt3-suspension-walkaround-5.jpg Views:	0 Size:	126.3 KB ID:	298743
                        And last, a fellow member has asked me to consider making a knuckle that is designed to:
                        1) Correct the geometry of lowered track cars (this would have the effect of making more stable geometry and also increase front roll stiffness, so you can soften the front sway bar and still get good roll control)
                        2) Move the strut mount more inboard so you can fit more front tire by going inward
                        I've been thinking more about this, specifically #2, and how I think we might be able to mitigate the downside of the increased bending moment on the strut tube from relocating it inboard. If we play our cards right, we can achieve another 20mm or so of inner tire clearance AND stiffen the strut up to make it respond even better to mid-corner damping and displacement changes. And also last longer, because it will be bending less. So this is intriguing and I may pursue it. Again, see below from Porsche for inspiration, noting the two clamps on the strut, one of which is placed very high up:
                        Click image for larger version  Name:	991-porsche-gt3-suspension-walkaround-7.jpg Views:	0 Size:	144.0 KB ID:	298744
                          I thought you were doing a custom control arm as well? If that was the case, you should convert to that design anyway.
                            Yeah I was kinda hoping to make each part a bolt-in but you might be right, just go full send. Let's see where the math takes us first.
                              Couldn't help it, dropped the control arms and tie rods 30mm and added a second strut support 80mm higher, then tipped the strut in 4 degrees for ~20mm extra inner wheel and tire clearance. Here's the unrestricted by manufacturing constraints result:
Name:	Screenshot 2025-03-22 at 11.38.02 PM.png
ID:	298785 Click image for larger version
Name:	Screenshot 2025-03-22 at 11.38.10 PM.png
ID:	298784 Click image for larger version
Name:	Screenshot 2025-03-22 at 11.38.20 PM.png
ID:	298786 Click image for larger version
Name:	Screenshot 2025-03-22 at 11.38.30 PM.png
ID:	298782 Click image for larger version
Name:	Screenshot 2025-03-22 at 11.38.38 PM.png
                                Had a revelation today. I've been struggling to get the stress analysis to close ever since I started modeling the tie rod tapers as 4340 steel mating parts. I remembered that the e39 used a taper like the e46 does, and also had aluminum uprights, so I couldn't figure out why my analysis wasn't closing. Well, it's because the e39 has a steel insert where the loads would otherwise fail the aluminum part. Nice, that'll do it.
Name:	Screenshot 2025-03-26 at 8.31.38 PM.png
                                So looks like I need to make a trip to the junk yard this weekend to rip some of these bushings out of an e39, take some dimensions, then see if I should use the e39 bushings or design mating parts for the e46. I fear that there is not enough thread engagement on the e46 M3 control arm to use the e39 bushings as-is, so they'll probably need to make a trip to the lathe.
                                e39 bushing being pressed out (instead of the ball joint) to visualize it:
                                Click image for larger version  Name:	1089.jpg Views:	0 Size:	62.5 KB ID:	299336
                                and the bushing after it came out:
                                Click image for larger version  Name:	1090.jpg Views:	0 Size:	182.8 KB ID:	299337
