Black & Tan 332iT
    Thanks guys, I’m enjoying this project as it’s giving me a chance to really test out Fusion 360 and generative design.
    Tonight I worked on some lightweighting and managed to get this down to a .09kg weight penalty over the single clamp version. So we’re pretty much maintaining the 1lb (.92lb) unsprung mass reduction. Pretty good I’ll say!
    And thanks to a member on e46fanatics we now have a visual and measurement of heatshield clearance - 3.25mm to the rotor - snug.
    The latest:
Name:	Screenshot 2025-07-31 at 10.32.14 PM.png
ID:	313980 Click image for larger version
Name:	Screenshot 2025-07-31 at 10.34.31 PM.png
ID:	313979 Click image for larger version
Name:	Screenshot 2025-07-31 at 10.31.15 PM.png
ID:	313978 Click image for larger version
Name:	Screenshot 2025-07-31 at 10.31.45 PM.png
    Off to the printer(s) we go! (George is printing one too)
Name:	Screenshot 2025-07-31 at 12.55.46 PM.png
      Ran a quick analysis on the stock parts assuming they're a similar enough material to 4340 and here we go - large deformations leading to camber loss. 11.5mm of displacement at the strut tower ~= 1 degree of camber. So at 1.6G, the factory parts are losing 7.2/11.5 = 0.63 degrees of camber, compare this with 2.0/11.5 = 0.174 degrees of camber in the latest knuckle version. Excellent.
Name:	Screenshot 2025-08-01 at 8.32.27 PM.png
        I didn't want to steal @Bryson thunder, but I have been man handling the latest design for a couple days now and its really impressive.
        The part is 255mm "tall" and my printer max dimension is 256mm so pretty tight, but we got it fitted. After a couple fails I got a mostly "perfect" print.
        The ball joint inserts printed in a different color and press nicely into the knuckle (and yes, I realize I could have picked a better color lol)
        I really thought this was cool to see the evolution of his design and idea. The red one is the very "first" design compared to now. Bryson will correct me if I am wrong but if I recall the green one is stronger but still the same weight as the red one.
        Email to [email protected]
          I can feel the weight savings in my wallet, looking at these pictures 🤣
            Given any thought to moving the lower mount points downward, to restore geometry for lowered cars?
              Well, my car isn't lowered, so...
              I may give it a shot after the first prototype shows up - got an ideal target for lowering? 30mm? One nice thing is that the loads will be lower on that version because the ball joint will be closer to the ground.
              I'm still pretty hesitant to let this out into the wild given the liability/risk of a failed part though honestly.
                I wish my car wasn't lowered at all. Aftermarket shocks often just don't play nicely with that-- if you want any droop travel, often you must lower the car (especially in the front).
                ... let me ponder the optimal amount it would target. Certainly don't want to get into a situation where 18s are no longer viable (don't know if we'd be anywhere close to that).
                Just release it as for fun online viewing of CAD files, not for use on cars, etc :P
                  I took a look at this last night in more detail. Cursory analysis limits it at about 15mm before you need to change Ackerman or kingpin inclination axis as the tie rod will impact the heat shield if you go any lower. At about 30-35mm lower the tie rod will actually impact the rotor. Now I see why Porsches run 50mm front offsets without such flat wheels, it’s a hell of a packaging challenge. One way to gain clearance is to move the rotor out a few millimeters, which would then necessitate higher offset front wheels to maintain reasonable scrub. It’s doable but you introduce tradeoffs, which in my opinion would be worth accommodating.
                  You’d also be able to run 18s in either scenario.
                    Just went out and measured (never had before-- set height by bump/droop travel, and then corner balanced from there), and it appears my car is 13mm lower than nominal/spec e46 M3 ride height.
                    So, I guess for me, 13mm would be optimal...
                    ... or is it less, since I'm measuring at the face of the wheel and there's some motion ratio effect? Maybe 12mm would be optimal...
                      Center of the wheel to fender is the number I’m looking for, just in the vertical plane
                        For what it's worth when I was looking into those adjustable tie rod kits with some track nuts, someone said the E46 M3 knuckle retains good geometry and minimal to no bump steer when lowered and doesn't need nearly the correction a Non-M could.
                        As someone who daily drove a non-M for over a decade, most lowered (like my now M3), I can confirm I never even think about bump steer anymore. I'm also not an engineer and am unaware of other negative drawbacks when lowered.
                          13mm lower than nominal as measured purely in the Y.
                            That’s interesting, I wonder if this is what drove the steering ratio change? Would be interesting to scan a non-m knuckle and overlay them as I’d be surprised to see much of a difference.
                              I have one rusting on my back patio. You making a trip back up? They're much easier to get ahold of though.
                                Yeah at some point here I’ll make the trip up. Or Heinz can scan it
