Originally posted by heinzboehmer
View Post
Flashing the MK60 with ZCP software
Worth having a read through this section of the facts.md as well https://github.com/cmg5461/mk60e5-fi...?plain=1#L1052
Yep! Should have given a bit more context.Originally posted by karter16 View Post
On the MK60e5, the seed/key pair gets you "coding" access (security level 2). To get programming access (security level 5), you need to authenticate with a 128 bit keyed-MD5, which is fortunately stored in FW, so all you need is to read through a dump to find it.
The catch is that you need that FW dump to find the key that gets you programming access, but you also need programming access to get a dump from the MK60 non-destructively. If only BMW had given us a .0pa for it...
Then there's also the problem of signing a modified image. This part uses RSA, but it isn't super secure on the MK60e5, so you can find the private key by factoring. I'm guessing this step will be similarly trivial on the MK60.
It's looking like I'm probably going to have to get another MK60 unit to open up and read the flash directly from. But no sense in doing that if I can't first verify that the unit actually supports programming mode (or some other method of getting to the bootloader).2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
If you share whichever keys you need factored, I should be able have my computer going at it. These days I can do them in under 24 hours each.
does your disassembly indicate whether the pre-BN2000 can communication and K-line mode exist at all in the code? I had hoped there would be a configuration switch since the Z4M Mk60e5 module does speak the old language.
I think it might be reasonable to poke at the modules with CCP and XCP comms anyway, not impossible for BMW to have left it in an older module. Someone I was corresponding with found the E60 dsc module did leave XCP open and allowed for a full dump
- Likes 3
heinzboehmer If you need an MK60 that can be sacrificed, I've got a few non-M here I will gladly send you.'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
Email to [email protected]
- Likes 2
Awesome, will send some keys your way when I get to that point.Originally posted by terra View PostIf you share whichever keys you need factored, I should be able have my computer going at it. These days I can do them in under 24 hours each.
I'll need to check the disassembly for that when I get back home. I left the LLM to reconcile the work it had done in ghidra with the disassembly and symbol attribution work in that other repo. Hoping to have a nice and clean ghidra project to share soon, so that others can look through it too.
And good to know about XCP! I have a script to poke at the MK60 both via CAN and K line to try and get to the bootloader, but I haven't tested it yet. I've got an 817.3 module in my car and it would really suck to mess that one up
I'll definitely take you up on that!Originally posted by George Hill View Postheinzboehmer If you need an MK60 that can be sacrificed, I've got a few non-M here I will gladly send you.
I do think there's a lot to learn from the non-M modules, but I also fear that they're gonna be missing the flashing functionality in the bootloader. Getting a dump of the program would still be very valuable.
Internet lore says only 813.3/817.3 can be flashed, so unsure what the path is for the non-M modules. I would be surprised if the HW was limiting the flashing and instead expect that the 813.3/817.3 were the only ones that shipped with the FW routines for flashing.
Wouldn't be surprised if the non-M modules can be BDM flashed with the fully featured bootloader, but that involves both cutting the case open and having a binary to flash.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
