Flashing the MK60 with ZCP software
    Oh shit, I might have found CCP commands in the PT(?)-CAN table.
    Table decodes out to a bunch of CAN IDs that I was going through and, after some indirection, I found a read of the presumed-CCP EEPROM flag through a function pointer. Fortunately 0x797 was the towards the top of the table
    Looking through the payload handler:
Name:	Screenshot 2026-10-30 at 1.28.47 AM.png
Name:	Screenshot 2026-10-30 at 1.20.47 AM.png
    tbl_0f2eb:
Name:	Screenshot 2026-10-30 at 1.21.40 AM.png
Name:	Screenshot 2026-10-30 at 1.49.32 AM.png
    (I still don't know what the `_DAT_00400948` check is. Presumably a `wheel_speed == 0` check since it comes from RAM?)
    So now we know the second conditional in `can_rx_797_payload()` will evaluate to true (because the CCP flag is set). If we go to the function that gets evaluated in the conditional, we see something that looks suspiciously like an interpreter:
Name:	Screenshot 2026-10-30 at 2.24.00 AM.png
    Looking at a CCP command ref (e.g. https://mxhelp.danlawinc.com/ccp_xcp_reference.htm), the `UPLOAD` function (0x4) is immediately interesting. Follow the function call in `case 4:` and jackpot:
Name:	Screenshot 2026-10-30 at 2.05.16 AM.png
Name:	Screenshot 2026-10-30 at 2.05.39 AM.png
    An unauthed, unbounded read in a loop that writes to a buffer (ignore the decompiled C code in that last screenshot, it's not looking all that great). Looks like the `UPLOAD` function to me!
    Lots of words and code to say that I was wrong and I'm now pretty convinced that CCP is supported on the e5 AND it can dump flash.
    Since the EEPROM flag is present on the MK60 dump, I'm pretty confident that it will be supported there too. Amazing.
    I know what the first thing I'm going to do when I get that MK60 is!
      Oh baby! Now we’re getting somewhere
        Nice work Heinz - this is epic! very much enjoying following this along!
        FWIW pretty much all of the weirdness in the Ghidra C-code view can be resolved by making sure your function parameters (number and datatype) and return value (datatype) are correct. For example
        Code:
        int can_rx_797_payload(void)
        I'm willing to bet if you follow where it's called the return value isn't actually used. If so, and you modify the function prototype in Ghidra to be a void return type you'll see a bunch of that weirdness clean itself up.
          Code:
          That's good to know! First time using Ghidra for this kind of work, so still stumbling through it. Will try to fix all this weirdness now.
          Edit: Oh man, it's so much nicer with these fixes. Thanks! Repo updated with this in mind, so any .0pa you feed the workflow will generate these nice Ghidra projects automagically.
