    Originally posted by sda2 View Post
    As I said earlier, awesome work! Did you go through the SMG CAN implementation by any chance? It would be awesome to ditch the SMG and install DCT or 8HP with a CanTCU, but for that the secondary CAN bus needs to be deciphered.
    Afaik the MSS54 acts as a gateway between the gearbox and the chassis, so the can11h message "EGS1" on 0x43F is actually sent out by the DME, not the SMG control unit.
    SMG CAN starts at something like 0x410 up to 0x412. I think olza also posted about this.
    I haven't had a chance to get into the secondary CAN yet. But having a very quick look now.
    There are 11 outbound messages from the DME.
    0x310
    0x311
    0x312
    0x313
    0x314
    0x515
    0x710
    0x711
    0x712
    0x720
    0x701
    The 0x7xx messages I'm pretty certain will mirror the convention on the primary CAN and will be diagnostic messages from when BMW were developing and tuning. They seem to contain unrelated parameters that would be useful for tuning. Their sending is controlled via parameters in the partial ROM.
    There are 3 inbound messages that are read as you've previously identified.
    0x410
    0x411
    0x412
    I'll get into this more when I get the chance ​, but that seems to be the high level.​​​​​
    Edit: Also yes - 0x43F is sent from the DME on the primary CAN.
    Build Thread:
      Yes, anything 0x7** is development stuff, yes. I was unaware of the 0x310-515. I only know 316,329,338 and 545. So MSS54 is indeed very special.
      SliM3 I know the Maxx and Dodge firmware, but after driving a Dodge one, I have to say that BMW is way better for daily use, than Dodge.
      How do you hook up the Maxecu? splice it into the existing DME wiring, or is it capable of reading the values from can? How is throttle blip and ignition retard working?
        You can use the MS43 plug-n-play harness adapter, which is what I'm doing - although you might need to move a few things around. I'm also using a MaxxECU, with an e92m3 DCT, but a turbo Honda k24 in an e46. I'm using the MS43 play-n-play harness, but I made a custom Honda k24 engine harness to BMW DME style x60003/x60005 plugs so everything is very factory.
        Here is the wiring documentation: https://www.maxxecu.com/webhelp/wiri...u-bmw_m54.html
          Perhaps we can move this to a dedicated SMG/DSG thread?
            Perhaps we can move this to a dedicated SMS/DSG thread?
            Yeah, my bad for jumping OT! Agreed 👍🏽
              No worries Brian. It's a really interesting topic in its own right.
              All the best
              Ac427👍🏽
                Couple of updates:
                I've confirmed that the 0x4000 - 0x7FFF memory space is non-volatile memory used for storing things like the AIF Counter, Stored DTCs, trims, etc. that persist between drives.
Name:	Screenshot 2025-08-17 at 7.27.45 AM.png
                Also this is the latest memory map - it's still incomplete in that I know I need to add the 2x CANbus frame buffers at 0x00ff0000 and 0x00ff1000) among a range of other things, but I want to do some more confirmation around those before I add them to the table.
Name:	Screenshot 2025-08-17 at 7.27.51 AM.png
                Build Thread:
                  Have finished the CSL specific section of the Load Detection (Lasterfassung) module in the XDF. All parameters are named, with descriptions and correct conversion factors and units of measure.
                  Pretty much the only way this section will get more accurate now is if someone who has them shares the actual BMW names for these parameters, but that's really just a nice to have, it wouldn't change the understanding of what these parameters are and do.
Name:	Screenshot 2025-08-23 at 5.41.28 PM.png
Name:	Screenshot 2025-08-23 at 5.42.17 PM.png
Name:	Screenshot 2025-08-23 at 5.42.28 PM.png
Name:	Screenshot 2025-08-23 at 5.42.35 PM.png
Name:	Screenshot 2025-08-23 at 5.42.44 PM.png
Name:	Screenshot 2025-08-23 at 5.43.06 PM.png
                  Build Thread:
                    Posted this in my build thread but thought it was worth putting here too:
                    Now that I'm setup for CAN logging I finally got a chance to try out my custom program and tune ROMs that allow for configuration of the additional CAN messages (7D0 and 7D1) in the partial binary (see here for the background: https://nam3forum.com/forums/forum/s...454#post310454).
                    The good news is that it all worked first time! (to be fair I put a lot of effort into checking and rechecking the code to make sure it was right)
                    First up I flashed the custom program to the DME and ran it with the standard tune. I've designed this such that if someone uses the custom program with a tune file not designed for it the additional functionality is simply disabled. Likewise if someone uses the custom tune with the standard program it is also gracefully handled.
                    I then verified that DME functionality was as expected. E.g. normal function and no additional CAN message activity. All was well.
                    I then added the new parameters to my tune file:
                    Click image for larger version  Name:	Screenshot 2025-08-24 at 2.35.35 PM.png Views:	0 Size:	162.0 KB ID:	316508
                    and flashed the tune. Sure enough everything still worked, and the 7D0 CAN message was present on the CANbus.
                    Here are the values being logged.
                    Click image for larger version  Name:	Screenshot 2025-08-24 at 2.53.16 PM.png Views:	0 Size:	146.5 KB ID:	316509
                    I've got some more scenario testing to do. e.g. test the 7D1 message as well, intentionally put bad data into the config parameters and make sure it's handled gracefully etc. but super stoked all is working so far as this is the most complex change I've made to the program so far!
                    Onwards and upwards - this functionality will be very useful to me as I dive into more refinement of my tune now I have high-frequency CAN logging available!​
                    Build Thread:
                      Man, that's super cool. Good stuff!
                        karter16 Matt, have you looked into integrating into TunerPro RT? I believe the guys on the MS43 project have done so, you can check on their wiki, would be really cool way to log and tune in a single program.
                          Are we working to a point where we could use widebands with the factory ECU, to have live, on the fly, AFR corrections?
                            Oh my, that would be nice. Nobody working on this though, that’s a pretty massive rewrite. You might be able to just get that by using Z4M hardware.
                              I hadn't actually but will look into it - that sounds really cool and would streamline things a bunch. So much to do and so little time haha!
                              Build Thread:
                                Oh man that would be very cool. As Bryson says that would be a massive rewrite. It wouldn't just be about the actual code changes, but also the amount of research and investigation to understand, to extreme detail, how the MSS54 currently ingests the narrowband, plus how something like the MSS70 uses a wide-band and then figuring out how to bring them together. There's also all the hardware considerations (e.g. are there appropriate ADCs available on the MSS54, etc.). For the Civ fans it would be deity level difficulty. Not to say it couldn't be done, but it's certainly beyond my ability (although to be fair I think I said that about the CAN logging changes as well at some point, so maybe future-me will surprise myself ).
                                At the moment my main focus is on wrapping up understanding the CSL specific portions of the tune file and the code so that I can properly document all that and it's then available to the community as a reference. After that I really want to dig into the SMG code and work out the unknowns in that space, as once that's done we will have a truly complete XDF for 0401.
                                There's so many practical applications for what's being learned and uncovered and I certainly don't have the time or skill to chase them all. My hope is by making the information available it gives others the opportunity to pursue specific projects they are interested in.
                                Not to say I don't want to be involved in all these things, I just simply don't have the time to do it all!
                                Build Thread:
