    Something else that I've been looking at is a binary that terra shared with me that came from a brand new CSL DME. This DME in particular was shipped without the tune file programmed to it. In its place is what I believe is a manufacturer test software to test the unit on the (Siemens) assembly line.
    the MSS54 bootloader has provision to jump to this location (there's actually a DS2 call to perform the jump) and treat the region as code.
    The software appears to be a basic main loop that handles communications between the master and slave processors, as well as a very DS2-like communications protocol (literally the only differences seem to be the message ID and length bytes are swapped, the checksum calculation is different and the actual device/command IDs are different) on the same pins as DS2.
    The functions that can be called all test different aspects of the DME and CPU hardware and validate their functionality.
    There are also several functions for reading/writing/wiping the flash memory. Crucially the function that wipes flash sectors includes the ability to wipe and write to the bootsector. You can probably see where I'm going with this...
    1: Load the code into the tune sector in place of the tune
    2: DS2 call to jump to the program
    3: Wipe bootsector
    4: Write new bootsector
    5: Reboot DME
    6: Write new Program for new bootloader
    7: Write new Tune for new bootloader
    8: Fin.
    It would be trivial to extend the MSS54 DS2 Tool to use the modified communication protocol when needed, but this introduces a different risk, which is that when the DME is in the car there are other modules listening on DS2 and the possibility can't be discounted of a packet being seen as valid by one of those other modules and causing unintended havoc. Therefore I think the way to go is a small wrapper that translates standard DS2 calls into the format required by the manufacturer test code. That way comms to the DME stays compliant with the DS2 protocol but also means very minimal change to the test software.
    This will be fun to see if I can make it work, but will need to wait until I get hold of a second DME as don't want to be regularly taking my main DME apart to BDM recover it which will inevitably be required for this project.
    This would enable the following functionalities:
    - Change bootloader over OBDII
    - Clear EWS and perform an initial sync
    - It would also significantly lower the barrier to use should we want to make any bootloader-level changes as part of 0401 Community Patch in the future.
      Just pay me for shipping and I'll give you a DME, as my contribution to this project :P
        I'll pay for shipping for you to ship to to him. Sent you pm.
          Well enormous thanks to bmwfnatic and ZiMMie - DME is on its way to me. This means I'll be able to put together a bench setup that will allow for lots more experimentation (and a greater tolerance for failure!). I'm very grateful to you both, this community is amazing!!
            3: Wipe bootsector
            5: Reboot DME
            8: Fin.
            Great work there! Sometimes my data hoarding is useful ha
              Have you looked into how the ‘emergency program’ / limp mode operation works?. I’m wondering what changes it enables when it kicks in and any adjustability
                Yep I have - and this funktionsrahmen document is fairly accurate if you're looking to get an understanding of how it works: https://github.com/karter16/CSL_0401...%20Concept.pdf
                Note that this doc doesn't talk to CSL-specific changes (specifically how rf (filling) errors are detected and escalated to the EGAS emergency program).
                in terms of adjustability what would you be wanting to change?
                  It was more of my curiosity than anything at this stage. I was just wondering if any changes could be made to the safety/operating state when sensors fail…. Eg. MAP, EGT or IAT etc.
                  i shall have a read of that document when I get a chance though as I’d missed that one completely.
                    Found a bug in the SMG background task:
Name:	Screenshot 2026-08-02 at 5.25.48 PM.png
                    The error check conditional checks LA1_ED twice. The second test should be LA2_ED....
