    Something else that I've been looking at is a binary that terra shared with me that came from a brand new CSL DME. This DME in particular was shipped without the tune file programmed to it. In its place is what I believe is a manufacturer test software to test the unit on the (Siemens) assembly line.
    the MSS54 bootloader has provision to jump to this location (there's actually a DS2 call to perform the jump) and treat the region as code.
    The software appears to be a basic main loop that handles communications between the master and slave processors, as well as a very DS2-like communications protocol (literally the only differences seem to be the message ID and length bytes are swapped, the checksum calculation is different and the actual device/command IDs are different) on the same pins as DS2.
    The functions that can be called all test different aspects of the DME and CPU hardware and validate their functionality.
    There are also several functions for reading/writing/wiping the flash memory. Crucially the function that wipes flash sectors includes the ability to wipe and write to the bootsector. You can probably see where I'm going with this...
    1: Load the code into the tune sector in place of the tune
    2: DS2 call to jump to the program
    3: Wipe bootsector
    4: Write new bootsector
    5: Reboot DME
    6: Write new Program for new bootloader
    7: Write new Tune for new bootloader
    8: Fin.
    It would be trivial to extend the MSS54 DS2 Tool to use the modified communication protocol when needed, but this introduces a different risk, which is that when the DME is in the car there are other modules listening on DS2 and the possibility can't be discounted of a packet being seen as valid by one of those other modules and causing unintended havoc. Therefore I think the way to go is a small wrapper that translates standard DS2 calls into the format required by the manufacturer test code. That way comms to the DME stays compliant with the DS2 protocol but also means very minimal change to the test software.
    This will be fun to see if I can make it work, but will need to wait until I get hold of a second DME as don't want to be regularly taking my main DME apart to BDM recover it which will inevitably be required for this project.
    This would enable the following functionalities:
    - Change bootloader over OBDII
    - Clear EWS and perform an initial sync
    - It would also significantly lower the barrier to use should we want to make any bootloader-level changes as part of 0401 Community Patch in the future.
      Just pay me for shipping and I'll give you a DME, as my contribution to this project :P
        I'll pay for shipping for you to ship to to him. Sent you pm.
          Well enormous thanks to bmwfnatic and ZiMMie - DME is on its way to me. This means I'll be able to put together a bench setup that will allow for lots more experimentation (and a greater tolerance for failure!). I'm very grateful to you both, this community is amazing!!
            3: Wipe bootsector
            5: Reboot DME
            8: Fin.
            Great work there! Sometimes my data hoarding is useful ha
              Have you looked into how the ‘emergency program’ / limp mode operation works?. I’m wondering what changes it enables when it kicks in and any adjustability
                Yep I have - and this funktionsrahmen document is fairly accurate if you're looking to get an understanding of how it works: https://github.com/karter16/CSL_0401...%20Concept.pdf
                Note that this doc doesn't talk to CSL-specific changes (specifically how rf (filling) errors are detected and escalated to the EGAS emergency program).
                in terms of adjustability what would you be wanting to change?
                  It was more of my curiosity than anything at this stage. I was just wondering if any changes could be made to the safety/operating state when sensors fail…. Eg. MAP, EGT or IAT etc.
                  i shall have a read of that document when I get a chance though as I’d missed that one completely.
                    Found a bug in the SMG background task:
Name:	Screenshot 2026-08-02 at 5.25.48 PM.png
                    The error check conditional checks LA1_ED twice. The second test should be LA2_ED....
                      Karter16
                      You are amazing
                      This bug was fixed in 323_1801 (M3 MY 04 first M3 MSS54HP)
                      But thats only a very small bug in SMG clutch learning behaviour
                        Originally posted by ppm008 View Post
                        Karter16
                        You are amazing
                        Interesting! so BMW fixed for the standard M3 when they moved to the MSS54HP, but never bothered publishing a fix for the CSL specifically right? As you say it seems to be a pretty small bug, would be a bit of an edge case I think to cause any issue.
                          You are right.
                          The bug was also fixed for MSS54 nonHP in 322_1701, but never for CSL
                            Hi all,
                            I'm running an E46 M3 with an M54B30 + MS43 swap, keeping the original
                            SMG II. A Teensy-based gateway emulates the MSS54 side of the private
                            SMG CAN bus (0x310-0x314) for the SMG II TCU.
                            Thanks to Martyn's bench log (post #20) I got a long way. In return,
                            here is what I found by testing against the TCU's own diagnostics
                            (Tool32 SMG2 status_fahrzeugtester_lesen, ERRVAR ALIVE/SI DME10-15):
                            - 0x311: alive counter in byte2 high nibble, checksum in byte7
                            - 0x312: alive counter in byte0 low nibble, checksum in byte1
                            - 0x313: no counter, checksum only
                            - 0x314: alive counter in byte1 high nibble, checksum in byte5
                            - The checksum is "constant minus a sum of selected data bytes minus
                            the counter". Which bytes are included differs per message.
                            - 0x311 byte1: bit6 = brake light switch, bit7 = brake light test
                            switch, bits 0-1 = pedal high bits.
                            Happy to share full details with anyone interested.
                            All ALIVE/SI flags are now 0, and faults 129, 151, 153, 154 and 155
                            are gone. One fault remains active as soon as the engine runs:
                            128 "Fehlerhafte CAN Botschaft / CAN Busfehler"
                            CAN-Botschaft-Fehler = 0, CAN-Empfangs-Sende-Fehler = 32519 (0x7F07)
                            The gear display blinks as long as this fault is active. Things I've
                            already ruled out: bus termination (60 ohm), extra traffic on the bus,
                            0x315, 0x720, and the hardwired RPM signal (matches CAN).
                            My guess: the TCU expects the MSS54 to respond to its own requests in
                            0x410-0x412 (torque/idle intervention), and my gateway doesn't
                            answer them yet.
                            Could anyone with a working SMG car log the PRIVATE SMG CAN bus
                            (between the MSS54 and the SMG II TCU, not the chassis CAN) with the
                            engine running? Even 30 seconds would be enough: idle in N, select 1st,
                            a short pull-away and a couple of shifts. A raw log of 0x310-0x314 and
                            0x410-0x412 would answer the remaining questions.
                            If anyone knows how the MSS54 acknowledges the 0x410-0x412 requests,
                            that would help a lot too.
                            Thanks!
                              Originally posted by Camar81 View Post
                              Hi all,
                              answer them yet.
                              Thanks!
                              That is virtually impossible, as SMG (MSS54) and SSG (MS43) are completely different. With SMG, the DME handles the clutch position control; this function does not exist at all in the MS43 and would have to be retrofitted—which is completely pointless.
