You can't just flash a CSL full bin over an HP bin, the boot sectors are different and can't be accesed via the OBD port. You have to either flash the EEPROMs directly via BDM (or desolder and use a chip programmer) or you can flash a modified CSL bin that will run on the HP bootloader.
I literally just went through this. What seemed to work was let everything go to sleep. Lock the car and close everything. Walk away for 15 minutes. Come back, make sure have over 13.5 volts with a maintainer, and flash the prg immediately. It took two days for me to get this to work. I used Hassan's partial after overwrite so it was a Terra flash and then immediately a Hassan flash. It wasn't anything I was doing and it probably isn't anything you're doing.
I'm glad and not glad I'm not the only one with this issue. I didn't virginize my DME. I didn't clear the flashes either, which wouldn't help anyways.
Thanks for the advice but so far nothing has worked, not the terra file fix, or any other suggestion. Seems I have an issue with the software, possibly the DME might be bricked. Sending it to a friend to see if it can be made to work on a bench system.
well my friend with his bench tester, just said its likely bricked,, wont connect in with WINKPF or anything else(INPA).. anyone know of anyone that can unbrick this thing?
This just happened to me as well and I'm on a 2500 csl bootrom. This isn't my first time flash either.
The prg flash completed successfully then I went to cycle the key and everything tied to the dme completely started freaking out like the whole ecu corrupted. MSSflasher can't id the ecu anymore. F
Hello guys! I recently had a thread started of trying to troubleshoot the current state of my DME which was confirmed to be bricked from a mishap with MSSFLASHER.
In the course of this thread, Terra mentioned that I can my particular error by grounding pin 37 on the master and slave of the EEPROM. I was also in contact with
