MSS5x Binary Modification Tool Update
    Is the Map sensor option in this tool active regardless of DME version? In other words, if I don't have my HP DME flashed as a CSL yet, can I still select for the Map sensor swap in this tool?
      Originally posted by Keith_MN View Post
      Is the Map sensor option in this tool active regardless of DME version? In other words, if I don't have my HP DME flashed as a CSL yet, can I still select for the MAP sensor swap in this tool?
      I am not 100% sure how the tool will behave as I haven't used it, hopefully it prevents you selecting the MAP sensor swap, but unless you have the 0401 CSL software on your DME you cannot use a MAP sensor, the normal M3 versions of the software do not have support for one.
