Originally posted by WestBankM4
Cold start rattle 2-3 seconds then gone.
Originally posted by Cmamainer View PostNo, I was in contact with a member from the old forum that went by the name "Zaharias", he was having the same exact issue and had rebuilt the vanos like I had and changed the rod bearings with no improvement. His mechanic recommended changing the oil filter housing believing that it was allowing oil to drain from the topend while sitting for extended periods such as overnight and it seems he was correct.
The new filter housing comes with gasket and a BMW oil filter, no oil cooler O rings though.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
I think I have a similar issue. After the car sits overnight, I get a rattle for the first 3-5 seconds on the first start. No prolonged oil light, and it won't happen if the car has been recently driven. The sound also ends very abruptly, like flipping a switch (or sufficient pressure built).
Going to try to pinpoint, but sounds like I'll be replacing the housing.Last edited by Lavatoad; 12-17-2023, 07:21 PM.
Originally posted by WestBankM4 View PostI'm having these exact same symptoms, funnily enough, it only started happening AFTER I completed my top end rebuild. It has been making a rattling, knock sort of noise for 1-2 seconds upon a cold start, it's always in the morning when the car has sat overnight. Vanos has been upgraded to Beisan and had less than 500 miles on it at the time, so I knew it wasn't that but I too searched high and low for the source. Sounds like you found the culprit for me, I appreciate you updating this thread. Going to order an OEM piece and get to work, most likely upgrade the pulleys since I'll be in that general area anyway.
IMO this totally feels like a tensioner-not-tensioning issue, but like others I also have a new tensioner, so I assume there's some sort of pressure leak somewhere in the system. I didn't realize the oil filter housing had anything to do with that, and I'm willing to give it a shot, but at $500 for the part and pretty labor heavy to get out, I don't want to just throw it at the car for fun.
Check valve in the oil filter housing?BMW / E46M Interior & Trim Restoration.
I think I have this sound. It's the loudest when the car has been sitting for multiple days without being started. Then on first start only, I hear it for about 2-3 seconds. After it has been started once - even for just 5 seconds - I won't hear it again.
Leads me to believe it's the tensioner, but mine is new. I don't know if there's a wrong way to install the tensioner...I just tightened it in until i hit the torque spec.
In this video you hear it just briefly at the 5 second mark. It's not as loud as it was this morning when I started it for the first time in a week.
Originally posted by Andratch View PostI think I have this sound. It's the loudest when the car has been sitting for multiple days without being started. Then on first start only, I hear it for about 2-3 seconds. After it has been started once - even for just 5 seconds - I won't hear it again.
Originally posted by TexaZ3 View PostCheck valve in the oil filter housing?
I went ahead and ordered one from FCP along with a new tensioner, idle pulley, bolts and gaskets....we'll see if this is the fix!Last edited by Andratch; 07-31-2024, 11:08 PM.
Got the old oil filter housing out today, did not need to take off the fan. It only took about 45 minutes, not a difficult job…don’t let it intimidate you.
All you have to do is take off the intake (not the plenum, even with CSL intake), remove the driver side fan shroud piece, release the serpentine belt from the alternator, remove the alternator itself (two bolts, one clip, and one nut), then one bolt for the oil cooler lines, 6 bolts for the housing, and 2 bolts to separate it from the power steering pump. Easy peasy.
The tensioner comes out with the assemby, so I'm just going to replace that and the idle pulley at the same time because they're cheap and mine are original.
new one from FCP gets here tomorrow, we’ll see if this is the fix we’re looking for.2 PhotosLast edited by Andratch; 08-02-2024, 01:40 PM.
- Likes 5
Did you end up replacing your oil filter housing, and did that fix the problem?
Like you, I bought an OEM oil filter housing, the oil cooler o-rings (thanks Heinze) and a new OEM tensioner since that was the first part I bought after reading this thread. Problem is, it's still in the box in the garage haha. Let me know if it solved your issue please, regardless I'll be installing those pieces shortly.
