Originally posted by Orphee
[IMP] application: Version 1.1.14
* Shutdown all unused I/O ports
* Rename I/O Port defines so they are consistent
* Ignore values for coolant temperature that are outside of usual ranges
* Resolve issue with radio overlay button in BMBT UI causing the UI to jump back to overlay mode even when on OBC / Nav
* Add support for extended ASCII characters, since most BMW UIs support this encoding
* Resolve issue with BlueBus keeping vehicles awake via TEL ON by shutting it down when the ignition is turned off
* Resolve issue with BlueBus waking other modules up by pulling the I-Bus low just prior to sleep
On music count time, I'm a bit opposed to this as I find it to be frivolous information, but beyond that, while it's possible to implement, I couldn't do it correctly. The issue is that the BC127 doesn't provide any notification updates if the user skips playback on the phone (using the slider). This would lead to an inconsistent state between playback and where BlueBus reports playback to be.
-Ted
. I have "batch 2" sitting in my house right now.
Doesn't change how satisfied I am of the product though!
