Hmm. What year is the car? I have some pre-LCI non-M (2) users reporting that the IHKA goes to blower minimum at random.Originally posted by BubbaTree View PostGuys, not to pile on the current BlueBus issue, and this has probably been touched on before. With the BlueBus installed and working perfectly ( which I love!), the a/c will suddenly shut off. Both the fan and compressor go down at the same time, and restarting only lasts for a few seconds. Seems to be somehow dependent on the blower fan speed. I'll include a note of explanation when it's my turn to return the unit for the fix.
The "4" variants of the radios are EU only as they support TMC and Traffic Program, which the rest of the world doesn't useOriginally posted by Andy2424 View Post
you have a BM54?
Oddly, the "4" variants are also the only ones that build menus on the Nav UI for things like CDs and FM presets. Not sure why that wasn't incorporated into the BM53.
Thanks!
-Ted
Ted, I also noticed some weird AC behavior after I installed the BlueBus, but it was only on one trip and I don't recall the details. I think the AC turned off or lowered the fan speed on its own. I don't drive the car much right now so I don't have a lot of miles with the BlueBus. My production date is 6/02.Originally posted by BubbaTree View PostTed, the car is a 2003 vert SMG that was built October 2002. When the A/C craps out, the blower goes full off, as does the compressor.
Hmm my car's production date is 04/02 and I've seen that same AC behavior ever since I bought it. Every once in a while, the AC will completely shut off (display, button LEDs, fan, and compressor all switch off) for a second or so and then come back on. I installed some eBay bluetooth adapter (https://www.ebay.com/itm/Bluetooth-M...kAAOSw73Nan5EB) right after I got the car and recently swapped it out for a BlueBus. Behavior is exactly the same with both. I always assumed that my AC panel was starting to fail, but maybe it actually has to do with having something in place of the CD changer?2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
I don’t have the blue bus (YET, can’t wait though!) or any other Bluetooth/aux input and my A/C does what you describe. The issue seems random and not very common as I drive with my windows down a lot of the time when the temps are warm enough, even when it’s hot and steamy here in the Iowa most days. Unless you feel it’s directly related to the Bluebus. That’s for another new thread.Originally posted by heinzboehmer View PostHmm my car's production date is 04/02 and I've seen that same AC behavior ever since I bought it. Every once in a while, the AC will completely shut off (display, button LEDs, fan, and compressor all switch off) for a second or so and then come back on. I installed some eBay bluetooth adapter (https://www.ebay.com/itm/Bluetooth-M...kAAOSw73Nan5EB) right after I got the car and recently swapped it out for a BlueBus. Behavior is exactly the same with both. I always assumed that my AC panel was starting to fail, but maybe it actually has to do with having something in place of the CD changer?
Cool. Yeah I hadn't assumed it was related to the BlueBus until other people in this thread started reporting similar issues.Originally posted by Ruley View Post
I don’t have the blue bus (YET, can’t wait though!) or any other Bluetooth/aux input and my A/C does what you describe. The issue seems random and not very common as I drive with my windows down a lot of the time when the temps are warm enough, even when it’s hot and steamy here in the Iowa most days. Unless you feel it’s directly related to the Bluebus. That’s for another new thread.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
I can also confirm that since BlueBus installation, a/c has started shutting down intermittently. No codes in the IHKA module...12/01 build vert.Originally posted by heinzboehmer View PostHmm my car's production date is 04/02 and I've seen that same AC behavior ever since I bought it. Every once in a while, the AC will completely shut off (display, button LEDs, fan, and compressor all switch off) for a second or so and then come back on. I installed some eBay bluetooth adapter (https://www.ebay.com/itm/Bluetooth-M...kAAOSw73Nan5EB) right after I got the car and recently swapped it out for a BlueBus. Behavior is exactly the same with both. I always assumed that my AC panel was starting to fail, but maybe it actually has to do with having something in place of the CD changer?Last edited by m1ch@&l; 07-16-2020, 05:16 AM.
I didn't try to activate the blinker feature on the BlueBus, so my answer is "no" unless that feature is turned on by default.Originally posted by t3ddftw View PostHey guys,
Those of you having IHKA issues -- are you using the blinker feature? Does the IHKA shutting down correlate to using the turn signals at all?
It appears to be limited to pre-LCI E46s...
Thanks!
-Ted
I have a 2005 E46, and have suffered none of the aforementioned issues. Still running v1.11, have blinkers activated. This supports your thinking of pre-LCI susceptibility.'05 M3 Convertible 6MT, CB/Cinnamon, CSL Airbox&Flap, PCSTuning, Beisan, Schrick 288/280, SS V1's & 2.5" System, RE Stg 1&SMF, KW V2, CB PS, Apex EC-7R
Hello Ted, years ago I always had the same problem with a Grom module and only with a BM54 made by Becker. There were also some from Philips, it always worked with them. The problem was only with the BM, with the CD there were never any problems, such as suspending the IHAKA ...Originally posted by t3ddftw View Post
Thanks!
-Ted
##This is a bus problemLast edited by Andy2424; 07-16-2020, 11:59 AM.
