    Strange, when I did my 3M weather stripping I definitely didn't have any rivets to deal with, just screws, the trim pieces came off fairly easily.
    I also don't think any of the previous owners had taken the trim off as the weather stripping was in bad shape.
    The rivet fastens a bracket to the aluminum finisher to allow the finisher to attach to the body and probably provide some degree of seal position control. The way the bracket fits is such that there is an interference with the rubber seal making it tough to position into place with a new seal. I’m still wondering if there wasn’t a better design—like integrate the bracket shape and mounting points into the aluminum trim and make some shape change on the rubber seal if necessary . Here are some photos of the area…
      Had to sign up for an account to this forum just for this. In for 2 sets!
        FWIW mine showed up awhile ago, looks good, if it's not OEM it could certainly pass for it.
        Seems to be very good quality. When I install them I will post a pic.
        2004 Dinan S3-R M3
        2023 X3M Competition
          Still scared to install mine bc of this rivet issue. And it’s like 105° here 😭
          997.1 GT3 Carrara White/Black
          C43 AMG Diamond Silver/Red​
            Maybe a dumb question but does this rivet issue not come up if you choose to install the OP aftermarket weather stripping option? Is this something that’s only encountered with this OE style weather stripping?
              No. The aftermarket stuff is just some generic weatherstripping that is forced into place, especially around the rivet area. It is kind of a ghetto solution to be honest. I do not remember seeing a rivet but it has been well over 3 years since I did the aftermarket fix. The install for the OEM one gotta be different.
              2007 Imola Red Z4M Coupe
                Got it thanks
                  This is exactly how I feel.
                    Well you just drill out the rivet. I bought a Quinn rivet gun and rivet pack from harbor freight--1/8" Aluminum rivet back in, no problem. The issue is, seating the bracket. That bracket allows the finisher to attach to the body. Anyway, it's not THAT bad, it's just finicky. Make sure you line up your new seal to the tick mark in the trim finisher and stretch it to fit; hotter is better. And put a new foam seal over the riveted area to keep your paint from getting scraped by the bracket upon reassembly.
                      NO NEED TO REMOVE RIVET AND THE BRACKET ! JUST PULL OLD RUBBER OUT, SPRAY WD-40 AND SLIDE NEW STRIP IN.
                        Mine "arrived" today but post office has lost it lmao just my luck, hopefully it turns up tomorrow.
                          I'll try that method when I do the other side. The side I did do, there was no way the new rubber was going in there as far as I could see; but, I'll give your method a try.
                            It would be amazing if someone that installed these took pics and posted a writeup of how they did it for the rest of us slobs
                            2004 Dinan S3-R M3
                              I'l be waiting till after summer. Plenty of time for some of you to gift us with a pictoral guide.
                                I’ll have to suck it up and get it done in this heat within a week or so. Will try to make a DIY if successful.
