As you guys have identified, Supersprint will essentially do any (reasonable) pipe diameter with any jig they've created and it usually just requires a special request. Over time (and based on demand), they have been adding new part numbers to the catalog to cover these "special requests". As they already had the 63.5mm segment for the E46, it only made sense to add the 63.5mm rear SKU. They just added the new SKU last week so you're not crazy.
S54 Dyno Database
Originally posted by IND-Distribution View PostAs you guys have identified, Supersprint will essentially do any (reasonable) pipe diameter with any jig they've created and it usually just requires a special request. Over time (and based on demand), they have been adding new part numbers to the catalog to cover these "special requests". As they already had the 63.5mm segment for the E46, it only made sense to add the 63.5mm rear SKU. They just added the new SKU last week so you're not crazy.2006 Silber Grau Metalizat ZCP 6 MT
Will be very interested in a race muffler with 63.5mm piping, this will make the muffler quieter even by a bit. The weight is more key for me vs the SCZA, as well as the flow which might be marginally better on the SS. DM'ed.
Anything with that sharp 180deg bend will rob some power (DIXIS, Gruppe M, etc.), dyno looks a bit wavy. This happened to a friend with DIXIS exhaust.
If you dont care, Dinan has the best flow, 2.5in dual. After that I think it’s the SCZA or Scorza, then maybe SS Race. Id love an SS race with 2.5in piping just dont think theyd make one anymore.
What was your buddies set up like, headers, Sec 1, 2, cams, intake…..anything else.Last edited by CrisSilberGrau; 12-18-2024, 08:26 AM.2006 Silber Grau Metalizat ZCP 6 MT
Originally posted by paulclaude View Post
Nice power for the spec! The dip low down is due to the merge after the headers on the BW race. You won't be able to tune that out without moving the merge point in the exhaust to further back in the system (i.e. running dual pipes, then merging into single).
I had your canned tune for awhile and worked flawlessly for years! Very happy with it! Dyno’d at 325whp with it.
I switched because I needed a detune for a NASA class.
Originally posted by Nardo S54 View Post
Very impressive - how do you like your crappy Injen intake? is it modified in anyway?
Thinking of what the alternative will be,
It's crappy. Randy pointed out that being aluminum it absorbs a lot of heat which could help explain why the car sucks in hotter temps. He also noticed my IATs were high on the dyno. Randy recommended plasti-dip'ing it. Doing that now, we'll see if it helps.
Thinking of what the alternative will be,‘02 332iT / 6 | ‘70 Jaguar XJ6 electric conversion
And I agree with above, I’d use heat reflective tape around the intake pipe and heat shield to see if that helps work lower IATs.
Funny enough I am going through same thing based on feedback from Epic. I am trying to stuff the largest cone filter inside the factory airbox (goal being more flow without the heat). I’d be happy just getting to 310whp…
- Likes 3
