S54 Dyno Database
    Very first dyno so no baseline. APE flex fuel kit, B-Spec tune, catless headers. Ethanol blend @ E53
      Stash1,
      I use to live at that side of the pond I am not a fan of how European's do a dyno.
      Their dyno relays on crank or called flywheel hp.
      Whit another words, no one knows how much is the dyno calculating the drive train loses.
      Why I like Dyno-Jet at 14% drive train losses some consider 15% bit I am at 14%.
      Std E46M3 on dynojet puts down somewerw between 275rwhp to 280rwhp. Ones you have
      that % figured and then you ad parts you know the gains at the crank by calculating 14% One
      takes 333hp crank SAE and -14%-15% you come up to that number +/- with very small
      variations like weather temp, humidity, worn out engine etc are subject to this minimal variation.
      I have friend in EU Germany who tuned his E39M5 and per the dyno and tuner he pulls 460hp crank
      only from Tune. There is no S62 in existence that will produce 60hp at the crank gain from 400hp
      factory crank hp, from tune only !!!! period put on pump fuel.
      S62 with the best spoke tune will make ~25-30hp crank maaaaax. 415 SAE crank - 14%= around
      356rwhp. So 460hp DIN - 22% should match what a healthy tuned S62 will produce in US Dyno-Jet.
      Per our US calculation 460hp crank - 14% we should see 396rwhp dyno-jet something that will
      never ever happen from tune only. Perkins build S62 will be in that range of power.
      Dyno HP should be calculate coming from Factory numbers. Meaning if we take std E46M3 to
      a European Dyno we should see exact in the range 339-343hp crank....as how BMW AG
      advertised in EU E46M3 at the Geneva autoshow back in 1999.
      US dyno do fluctuate by tremendous amount and one will never see consistency as how we
      see her in US using Dyno-Jet.
      Regards,
      Anri
      It says 295 whp and 373 bhp and 78 hp losses as tested/uncorrected. the corrected "flyhweel" numbers are 375 hp / 273 lb-ft. which is fairly close to a CSL albeit the cams are little larger hence numbers are a almost 20bhp higher torque numbers similar
      Not sure the relevance of m5 example, there are s54 dynos flung about on these forums with more rwhp than flywheel estimates for the same mods so funny business on both sides.
      the Maha is fairly reputable dyno brand, they are in the US to but most operators dont seem to use the coast down feature in these jurisdictions
        Originally posted by stash1 View Post
        Yep, think we’re on the same page. When I said the avg. stock M3 makes around 275-ish WHP...I was referring to SAE Dynojet numbers. What I’m still puzzled about though is the fact the Martyn’s projected 340-360 BHP number is about on par w/our DJ numbers w/similar mods...yet his stock base numbers seem way higher than our WHP numbers?
        it baselined at 281whp which is a bit higher than stock but its a euro car, has the eventuri which eliminates the bulk of the losses from the induction system and it has a aftermarket ECU so its a straight forward thing to tune fuel PW and timing, ignition timing, vanos etc.
        A stock M3 makes 285 ish on a DJ if its running right which would probably be slightly more than that if it was low mileage to so not much inconsistent there.
        The elephant in the room is cams and airbox netted like ~15-20 numbers maybe, its a bit hard to tell as the corrections are only applied to the flywheel numbers and the rotating mass changed from 50-70kg but that’s a lot less than what many would have you believe even accounting for the eventuri
          Digger,
          I always see them in the range of 272-282 at max put on pump 91 gas.
          Again small variations may vary in the the settings which contribute what you are seen
          or experienced.
          Correct, exactly what I have calculated in previous post. 378crank HP or (BHP UK)
          minus 22% which is Exact what this dyno calculates the losses in %
          Dyno-Jet per my personal experience have done quite few test is about 14%
          I never believed those who will put losses in 17%range..
          There is also another very important factor that plays roll in the dyno testings.
          - How low the car is, suspension changes can create losses, toe, axle changes due to
          being lowered etc.
          - After market wheels with much wider tires will also be considered as drag factor which
          All of this will reflect the end of the hp number.
          Regards,
          Anri
          https://www.instagram.com/euroclassicmotors/.
          www.euroclassicmotors.com
            Stan,
            Read the Dyno with cams and box etc.
            Do the math and you will see how much the dyno calculation will never make sense to you.
            Rear wheel 294rwhp. Crank says 378 BHP (crank HP). So, 378-22%= 294rwhp.
            Hope this will make more sense to you ?
            Regards,
            Anri.
            Click image for larger version  Name:	S54 Dyno.png Views:	0 Size:	825.7 KB ID:	35542
            I think I’m following...so, his car made 378BHP, and 294WHP...based on a 22% driveline loss vs. the more normally accepted 14-15%—correct? So, if we extrapolate, and figure the WHP based on say 14%, his actual WHP would be closer to 325? That seems a bit low to me (for the mods) vs. what I’m used to seeing. Typically, cars w/cams air boxes & supporting mods are in the 340-350WHP SAE on a Dynojet.
              Click image for larger version  Name:	A4DB5000-0B39-4744-9566-DE5572B43C29.jpeg Views:	28 Size:	174.4 KB ID:	35605
              Nice, seems like solid numbers for those mods! Was the B-spec an OTS tune or custom? Thanx for posting up!
                Yeah, think I’m following what’s going on now, and yeah...I’ve seen stock DJ numbers from high 260’s to mid 280’s on stock cars...depending on mileage, state of tune, etc. Yep, the delta struck me as odd too. I’m kind of used to seeing gains of 20-35 HP for cams/airbox—weird. Sorry Martyn, don’t want it to seem like we’re speaking about you while you’re standing in the room-lol. Think we’re just puzzled by the delta.
                  Digger,
                  or experienced.
                  being lowered etc.
                  Regards,
                  Anri
                  Yep, agreed on the % loss, and I would like to think that I’m pretty well versed on most things dyno related...but there’s always room to learn! I’ve just always been fascinated by it-lol. I’ve often wondered how suspension set up might impact dyno numbers as well. Would be interesting to actually be able to test for that stuff!
                    Lol don't worry about it dude. Trust me, I was expecting bigger gains with the airbox but no amount of vanos work could bring it any higher! Still a ~50bhp jump over stock isn't anything to sniff at.
                    Perhaps we need to start a 100-200kph time thread for those with VBOXs / Draggy etc.
                      Stan,
                      My Man, you keep confusing based on what you are used to see on Dyno-Jet.
                      Again, follow the logic here, UK will rate BHP crank HP much lower than BMW
                      AG advertised the S54 at 343 DIN HP Crank.
                      In this exact case, you do have the saying.... "Dyno is a tool to see the improvements from the parts being installed"
                      aka Before and After. So if Martyn's S54 base run is 200rwhp and after tune box etc makes 230rwhp
                      you have 30hp gain over the base run and that's it don't keep looking for logic to compare to DJ
                      Accept the European Dyno services again as tool for "Before and After"..don't try to search for logic of
                      what you and I are used to see.
                      Like I mentioned before never been fan of this hp presentation. I am also pretty much sure that Dyno-Jet
                      will have much stable weather factor calibration, I have seen the Dyno-Jet too change from different days
                      from 14% down to 13%. So very little % in weather factor changes.
                      Regards,
                      Anri
                        Stan,
                        Logic again, We assume BMW knows what they are doing. Those Engineers designed the suspension
                        dynamics and the Axle, Differential position, Camber and Toe around the STD right hight as how BMW E46M3
                        was sold off your local authorized BMW dealer back in 2001.
                        Think about what is happening with your car when its dropped. I assume your M3 is lowered
                        by at least 1.5" inches from std right hight ?
                        Use logic how the Axle do work. The more you change them in the Wrong degree the more load you
                        are applying to the bearings. Differential clutches do get load as well. The Axle outer and inner bearings
                        do receive drag/loads when not as horizontal as possible under loads. Tow plays big roll into all of this,
                        set the toe-in at 0.17-0.20, camber at low -1.5 and you will note difference on the track at your trap speed,
                        most likely not visible on the street but with track data you will see few mph less.
                        Now, how much HP/drag all of this will filter coming from your cammed engine the only way to find out is
                        spent time for testing. The losses may be very very micro down to none I have no data but I know for a fact
                        that Axels do not work well when they are not as horizontal as possible under load.
                        Regards,
                        Anri
                          Lets not start another dyno vs. dyno numbers debate - too many variables to compare from one to another. Numbers differ, dynos differ, they all have their positives and negatives. I personally prefer a braked dyno that can control ramp time to simulate actual road acceleration vs. a large inertial roller as per DJ which can't be controlled (on most DJ, anyway) - then you end up with acceleration times of the power run that differ from real world conditions. That load/acceleration difference can lead to inaccuracies in the tune when the car hits the road or track, especially for turbo/boosted setups. As for the coast down debate - it's exactly that, negative losses on coast down from ending RPM which is added to the curve to calculate for flywheel. How the dyno uses those measured losses can differ, but either way it's the most accurate way to determine transmission loss vs. a fixed correction factor.
                          Anyway, here's one from my own Dyno, on my own track car.
                          -Supercharged @ 10psi boost
                          -Schrick 288/280
                          -Euro Headers
                          -2.5" Dual Section 1, 2 - decat
                          -SS LWR rear silencer
                          -Shite local fuel
                          -AEM Infinity Standalone
                          575HP / 379lb/ft TQ
                            Cool, yeah, 50 HP over stock is def noticeable in the seat of your britches! Ya, actual acceleration numbers would be a better metric to go by...providing traction isn’t a factor.
                              Stan,
                              Regards,
                              Anri
                              Ahhh sh*t balls then, thought I was really on to something. Sooo, there is absolutely no way to make any type of comparison between EU BHP numbers and a Dynojet—got it! I thought that you were just saying that the driveline % calc was off...but it just doesn’t flush.
                                -Schrick 288/280
                                -Euro Headers
                                -Shite local fuel
                                575HP / 379lb/ft TQ
                                Nope, we’re def not going there! ...and nice Paul! Looks like a strong runner!
