Originally posted by duracellttu
View Post
Questions About Recaro Sportster CS Seats
Wow those look amazing! Who did you source them through? You using the BR sliders/mounts?Originally posted by Gt4 View PostFinally installed one of my set of Recaro Sportster CS into my Estoril M32005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
I bought a set from a member on M3post in Winnipeg, Canada. This set is brand new with Dinamica insert. I will get Cinnamon covers from Recaro Max and those are for my Interlagos blue M3.Originally posted by duracellttu View Post
Than I saw a local car for sale with those black leather Sportster CS. I bought the car only to get the deats Nd couple of other parts, doing a part out right now and will sell the car after or it will be my winter beater. Those were bought throught JRP in Canada in June 2020 and are pretty much new. I installed those in my Estoril/black M3 and I have 7yards of M Texture reproduction fabrics at home to do the interior of the Estoril and insert of those Recaro.
So I have E46 M3’s since 2006 and always wanted Recaro Sportster CS and now I have to sets within a month lol
The floor mounts are VAC Motorsport and Recaro sliders on driver side on Estoril. Passanger side has a Sparco floor mount which is higher that VAC.
I will try the Brey Krause adapter and oem electric sliders in the Interlagos M3.Send me a pm for Gt4 Composites carbon fiber CSL parts
Make sure you don’t mount the seat belts above the sliders with the Recaro sliders!Originally posted by Gt4 View Post
The recaro sliders are not designed for it, and will fail in a crash with that load.Originally posted by Gt4 View Post
I didn’t but can you explain why?
We actually source some sliders from the same company that makes recaros (identical design) and crash tested them— the seat came completely detached from the car with belts mounted above.
Recaro mounts and sliders for Recaro sportsters, sit at the same height as stock E46 M3 seats?
I want 1-2cm lower than stock.
My car has sunroof and when I went for a track day I had to remove the foam from the inside of the helmet to avoid touching the roof lining.
Iam 183cm tall.
I see obioban recommends some brands above.Last edited by zaharias; 09-29-2020, 10:11 PM.
1.83cm tall... do you drive a remote control car M3?Originally posted by zaharias View PostRecaro mounts and sliders for Recaro sportsters, sit at the same height as stock E46 M3 seats?
Iam 1.83cm tall.
You haven't really described any complete mounting solution. That said, it should not be a problem to get the seat 1-2cm lower than stock with most solutions on the market. I suspect if you only want it to be that much lower, you're going to have more issues with the seat being too low than too high.
HahahaOriginally posted by Obioban View Post
1meter and 83cm (I wrote it as we say it in Greek) 183cm.
What mounting solutions do I have?
I have power oem seats right now.
So one solutions is oem sliders with bk mounts and the other one is bk mounts and sliders?
Thanks Obioban
You can get 1-2cm by changing from power to manual adjust seat basesOriginally posted by zaharias View Post
Hahaha
Thanks Obioban
