Questions About Recaro Sportster CS Seats
I would like to test these out sometime. Looks really compact and streamlined.Originally posted by Bry5on View Post
Custom brackets are coming together, currently the final version is out for powder coat. Updates here: https://nam3forum.com/forums/forum/m...lack-tan-332it
v1:
v2:
Instagram: @logicalconclusion
I wired a resistor in so that the passenger airbags will always trigger, then ended up coding it to the same behavior anyway, just to take the guesswork out. Retrofitting the sensor into the CS looked like it could have been tricky and unreliable, so I opted to just always trigger the airbag and delete the sensor. No faults.Originally posted by trancenation View Postwill there be any sensor faults in the seats that we need to program out? if i were to get CS's i would intend on having the passenger seat sensor installed. etc.‘02 332iT / 6 | ‘70 Jaguar XJ6 electric conversion
has anyone been successful at wiring the recaro heaters with the OEM harness? i know some vendors make a plug and play retrofit, but was wondering if there was a DIY out there.Last edited by trancenation; Yesterday, 09:44 AM.
They won’t work properly, the electrical impedance is fundamentally incorrect. I retrofitted mine with e39 heated seat elements for factory like operation (OEM button) and quick heating. Prior to that I’d attempted to use the recaro/aftermarket style heaters.Originally posted by trancenation View Posthas anyone been successful at wiring the recaro heaters with the OEM harness? i know some vendors make a plug and play retrofit, but was wondering if there was a DIY out there.‘02 332iT / 6 | ‘70 Jaguar XJ6 electric conversion
Ask Marek what he does.Originally posted by trancenation View Posthas anyone been successful at wiring the recaro heaters with the OEM harness? i know some vendors make a plug and play retrofit, but was wondering if there was a DIY out there.
My seats work with the factory heat buttons.
2004 Dinan S3-R M3
2023 X3M Competition
But they don’t heat up as fast as the stock onesOriginally posted by 9kracing View Post
And I found the heat set point targets to be off as well.
+1 this is my experience as well.Originally posted by Bry5on View Post
But they don't heat up as fast as the stock ones
And I found the heat set point targets to be off as well.2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
You can also tweak the seat eater values, thiugh I forget how at this point. I found I was never using level two, so I made my level two the factory level three and made my level three more intense.
Did all this back when I still had stock seats, but sine I used e46 seat heater pads in my seats... still applied equally.
